kuli89 Skrevet Desember 5, 2015 Rapporter Share Skrevet Desember 5, 2015 Hi everyone, One week ago I had a Eu-kontroll and I have to fix something. Can you help me to find out where I can found this part, I mean some picture? I don't understand norwegian, thats why I need your help. The problem is : "5.3.3 Bærearmer og opphengsarmer :Komponent defekt, skadet eller sterkt korroder, Indre, Fremre, Venstre, Berearm foring" Thank You in advance for help. Siter Lenke til kommentar Del på andre sider More sharing options...
Bwana Skrevet Desember 5, 2015 Rapporter Share Skrevet Desember 5, 2015 It can be either the top horisontal arm on the right upper part of picture (which is car's left side), or the bottom front arm - where shock strut is attached. You normally replace the whole arm, not just the bushing. Siter Lenke til kommentar Del på andre sider More sharing options...
kuli89 Skrevet Desember 5, 2015 Forfatter Rapporter Share Skrevet Desember 5, 2015 You mean these two? Siter Lenke til kommentar Del på andre sider More sharing options...
Bwana Skrevet Desember 6, 2015 Rapporter Share Skrevet Desember 6, 2015 One of your arrows points at the upper rear control arm instead of front. You will however usually replace both the upper arms at the same time. The upper arms can be difficult to replace as the pinch-bolt that attach the arms to the hub assembly. http://www.bilforumet.no/topic/265246-skifte-ovre-baerearmer-pa-a4-stuck-lost/ The lower front arm is easier to manage. Siter Lenke til kommentar Del på andre sider More sharing options...
