Søk i nettsamfunnet
Viser resultater for emneknaggene 'volvo 940 problem'.
Fant 2 resultater
12" Fi BTL N3 - 3999,- kr (4500) - dual 2 ohm (1.4) only 1 month used without any abusing. just yesterday was little unlucky and make very small scratch on sub, absolutely nothing to worry, you can see it on last pics. Coils are in 100% mint condition . NEO magnets! Crazy sub for compete or daily using! ficaraudio.com N312 DUAL 1 | DUAL 2 Fs: 55.3 Hz Re: 1.4 Ohms/coil Qms: 7.69 Qes: .25 Qts: .24 Mms: 222g Sd: 480cm^2 Vas: 12.1 Spl: 91.1dB 1W/1m Bl: 28.8 N/A Xmax: 28mm Rms: 3000W Displacement: 0.18cuft | 0.18cuft MB Quart Discus 2000.1 - 2999,- kr - true 2000 watts RMS power! Give you more power than its rated, read forums! Same board as AudioQue 2200! Watch video how it can play :) Discus Series Class D Monoblock Car Amplifier RMS Power Rating: 4 ohms: 500 watts x 1 chan. 2 ohms: 1000 watts x 1 chan. 1 ohm: 2000 watts x 1 chan. PWM (Pulse Width Modulated) MOSFET power supply Wired remote bass level control included LED power and protection indicators Tuned Bass EQ (0-9 dB bass boost at 45 Hz) Soft start sound Preamp RCA outputs DC, short, thermal, and overload protection circuitry Unbalanced RCA inputs Damping Factor: >180 Variable input level control: 0.2V-0.6V Variable low-pass filter (35-250 Hz, 24 dB/octave) Subsonic Filter (15-35 Hz) Frequency response: 15-250 Hz Dimensions: 19.69"L x 9.45"W x 2.7H 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier. Selling them only because going to more power with more subs. Sub and amp located at Lørenskog, call me if you have any questions 4715100fem Here you can see how it play in my golf, watch in HD until the end: And here some pics:
Sikringen til fjernlyset i bilen gikk den er på 15A og som reserve sikring har jeg satt inn en 25A sikring!! går dette greit? eller skal jeg bare ta den ut til jeg får kjøpt ny sikring på 15A!! når jeg tok ut den 15A sikringen merket jeg at viskeren bak på bilen ikke fungerte!!! har dette noe sammen heng? for så vidt jeg vet så er det bare den ene sikringen som går til fjernlyset! så har da også sikringen til viskeren bak gått å da? HASTER!!!!!!!
