Waxoyl oppskrift
Mad_Maxx
Var en kar på hoodride.com som var så gei at han fant ei oppskrift på Waxoyl, det er den gugga de bruker for å bevare rustne biler uten at de forsvinner, for de som ikke visste det fra før. Slags halvpermanent rustbeskyttelse, vet bare at den her gugga skal det komme mye av på og i 1970 rekorden etterhvert ;)
Here is a recipe for home made "Waxoyl". It's an old fashioned rust treat-ment / undercoating:
2 1/2 quarts turpentine
12 oz. beeswax / candle wax
1 quart light machine oil
With a cheese shredder, cut the wax into the turpentine, stir until the wax has dissolved, (takes a long time; you can use very low heat (a warm room) to aid but be careful) and thin with the machine oil to a brushable / sprayable consistency. Apply liberally. You can use a hand spray bottle to get into closed-off sections if you have a small access hole.
Dream as if you'll live forever; live as if you'll die tomorrow.
James Dean
