dueno Skrevet Mars 27, 2006 Rapporter Share Skrevet Mars 27, 2006 Jeg selger min 300/2 forsterker. Denne er god som ny, ingen kosmetiske feil eller skader, 100% som ny. Pris ønskes på mail: terjeberg@funsms.no Features: Rated Power: 150 W RMS @ 1.5 ohm-4 ohm (11V-14.5V) Rated Power (bridged): 300 W RMS x 1 @ 3 ohm-8 ohm(11V-14.5V) THD at Rated Power: S/N Ratio*: >108.5dB below rated power Frequency Response: 5 Hz - 30 KHz (+0, -1dB) Damping Factor: >200 @ 4 ohm per. ch./50 Hz Input Range: switchable from 200mV-2V RMS to 800mV-8V RMS Dimensions: 13.4"L x 9.25"W x 2.36"H Differential-Balanced Input Topology: (1 pair of inputs) On-board Crossover: fully-variable (50Hz-5 KHz), selectable-slope LP or HP (12 or 24 dB per octave) Preamp Output: 2-channel (full-range, LP or HP) Speaker output connections: accept up to 8ga. wire +12V and Ground connections: accept up to 4ga. Wire Siter Lenke til kommentar Del på andre sider More sharing options...
pahf Skrevet Juni 24, 2006 Rapporter Share Skrevet Juni 24, 2006 Er denne solgt ? Siter Lenke til kommentar Del på andre sider More sharing options...
