selges: cadence wildbeast & digital monoblokk
e stens
Vurderer å selge en 12" cadence wildbeast i 30 liters lukket kasse og ei
digital monoblokk av merket pyle med betegnelsen plad 3300d.
Kjøpt nytt for ca 1 måned siden og er brukt i underkant av 20 timer.
info om forsterkeren:
1x600W RMS at 4 Ohms
1x1800W RMS at 2 Ohms
1x3600W MAX at 1.3 Ohms
Mono Block Subwoofer Amplifier
1 Ohm Stereo Stable
MOSFET Power Supply
PWM (Pulse-Width-Modulated) System
Double Sided Epoxy PCB Circuit Board
Gold Plated RCA Inputs
Custom Terminal Block for Speaker Connections
Thermal, Overload & Short Protection
Variable Low pass Filter (50Hz~150Hz,24dB/Octave)
Variable Subsonic Filter (15Hz~40Hz,24dB/Octave)
Phase Control 0-180 Degree
Remote Bass Level Control
Input Impedance:10K Ohms
Soft Turn-on/Turn-off
Side Leg Mounting
Red Lighting Illumination
THD: <0.1%.
S/N Ratio: >90dB
Input Sensitivity : 200mV ~8V
Freq. Response : 15Hz ~ 150KHz
Patent Pending
Heavy Duty Power Coated Heatsink
Dimensions : 8.6''(W) x 2.74''(H) x 15''(L)
info om subben:
Size 12”
Voice Coil 3” Four-Layer
Impedance 2 Ohm Single Voice Coil
Power Handling 700 Watts RMS/1400 PEAK
Frequency Resp20Hz - 500Hz
Magnet SizeDouble Stack 150 oz.
Selges for 5000,-
audi s2 aby
