Pioneer Premier deh-p770MP selges :)
Supertuner
Supertuner Supertuner IIID+
24-Station/6-Button (18FM/6AM) Presets
BSM (Best Stations Memory)
CD Player
1-bit D/A Converter 16-Bit
CD-R/CD-RW Compatible
AGC (Automatic Gain Control)
Disc Title Memory
Track Title List
CD Text CD Text
BMX Digital Enhancement
MP3 Playback Compatibility
Codec Support MP3, WMA, WAV, iTunes AAC
File System ISO9660-1,-2, Romeo, Joliet
Max Directory 8
Max. Folder # 253
Max File # per Folder 99
Max File # per Disc 65535
Multisession Disc Play
Random Play Folder/Disc
Repeat Play File/Folder
MP3 Bit Rate 8~320kbps or VBR
WMA Format WMA v7, 8, 9
WMA Bit Rate 48~384kbps, VBR
File Name 64 bytes
Folder Name 64 bytes
ID3/WMA Tag ID3 v1.0, 1.1, 2.2, 2.3, 2.4; WMA; iTunes AAC
Tag Length 64 bytes
Tag Data Track, Artist, Album, Comment
Tag Display On/Off
List Search File and Folder
IP-Bus System Expandability
IP-Bus System Control
XM Radio Ready Yes
Sirius Radio Ready Yes (External)
iPod Adapter Ready Yes (External)
Multi-CD Control
DVD Control
TV Tuner Control
Built-in Auxiliary Input CD-RB10 or CD-RB20 required
External Unit Control 2
Display Features
Display Type Deep Blue Organic EL (OEL)
Dot Matrix OEL Size 128x32 + 24x32 (Deep Blue)
Screensaver Movies 2 (Dolphin Jigsaw, Circuit Board)
Background Animations 4
Background Pictures 4
Level Indicators 3
Audio Features
Built-in Speaker Power MOSFET 50W x 4
Continuous Power Output 22W x 4
Equalizer EEQ (3-band Parametric)
Equalizer Presets 5
User Equalizer Settings 2
EQ-EX
Loudness 3 mode
Electronic Balance/Fader
Source Level Adjuster (SLA)
Crossover Network Two-Way Crossover
High-Pass Crossover (HPF) 50/80/125Hz, -12dB/Oct.
Subwoofer Crossover (LPF) 50/80/125Hz, -18dB/Oct., +/-12dB
RCA Preouts 3 pair (Front, Rear, Sub/Non-Fading)
Preout Voltage & Impedance Hi-Volt (4V), 100 Ohm
General Features
Remote Control 10-Key Card
Wired Remote Input
Cellular Mute
Detachable Face Security
Face Case (Included)
Warranty 2 Year
Premier
Premier Service and Installation
Perry
er kun blått lys.
Er egentlig ikke flashy :)
Kan dimme ned lyset i displayet veldig og..
Jeg HATER fjortiss spillere (tro meg) og denne spilleren kan jeg lett leve med (men jeg går to hakk opp i anlegg og trenger en mere avansert spiller)
MER avansert spiller? Ojoj, roter meg nesten bort i innstillinger jeg, med eq-ex aktivert ;)
Litt flashy hvis man ikke skrur av "reverse mode" eller hva de kaller det (inverterer fargene hvert 10. sekund).
Det er mulig å dempe lyset i displayet, men knapper og slikt lyser fortsatt like sterkt. Finnes en funksjon som automatisk demper lyset når man starter motoren / setter på tenninga (vet ikke om denne demper alt eller bare display)
Veldig fin spiller syns jeg, selv om den mangler RDS.
avansert som i tidskomp osv :)
er lett å rote seg bort i innstillingene osv på denne ja :)
Du har DIMMER ja.
reverse mode suger hehe trykk på tast 5 så er du kvitt den.
Og jeg sier det igjen... jeg er 26 år... og driver seriøst med "anlegg" og jeg mener ikke det er noe spesiellt fjortiss preg over denne spilleren.
Har ingen betenkeligheter ved å bruke en US spiller siden jeg ikke akkurar bruker radioen så ofte at det gjør noe men på denne er det EU radio så jeg har brukt radioen litt nå og da bare for morro skyld så det eneste minuset for en RADIO lytter ihht denne spilleren er da RDS som nevnt ja..
Perry
