cerwin vega stroker 124.to stk 12" med to kasser vurderes solgt..
soundlord
Brukt et halvt år.Er som nye enda.Selges med lukket og portet kasse. Begge kassene er trekt opp.Den som er portet har 4 stk 4" rør.
specs:
The all-new Stroker Series is a revolutionary dual-spider design and is the most advanced subwoofer in mobile audio. Offering new design technologies and materials, the series includes 10- inch, 12- inch and 15-inch models.
The Stroker exemplifies the tradition of the original Stroker. It?s dual spider design maintains linearity and stabilizes the speaker in extreme excursion conditions. The new Stroker epitomizes high-output, high-performance subwoofers and has a linear operating range to an incredible 29mm in each direction.
The Stroker can handle an amazing 2000 watts of power and provide more than two inches of peak ? peak excursion when loaded into a ?High-Q? enclosure. Because of the extreme power capacity, a unique aluminum basket was designed to increase efficiency, thermal power handling and reduce thermal compression. The voice coil is placed directly next to an aluminum heat sink that is integrated into the basket. The basket design employs external heat sink fins to help dissipate heat pulled away from the voice coil to the outside of the enclosure. In a sealed enclosure, this reduces the internal ambient heat by as much as 50%. Another technology breakthrough is the unique motor geometry, which allows extremely high excursions with shorter voice coils than conventional designs. This results in a woofer with extremely high SPL capability while maintaining high sensitivity.
Service issues were addressed by developing a field replacement cone assembly. The removable spider tower and alignment access holes in the back plate, combine to allow simple field replacement procedure. Further enhancing the process is the unique Axial Surround Clamping System, which allows the cone assembly to be replaced without glue and provides a larger surface area for increased SPL.
12" Dual 2 ohm Voice Coil Subwoofer
(Preliminary specifications subject to change.)
* Peak Power Handling: 4000 watts
* Program Power Handling: 2000 watts
* Sensitivity: 84 dB 1w/1m
* Ellipsoid Surround
* Integrated Voice Coil Heat Sinking and Modulation Ring
* Extremely High-Temp Dual Coil Design
* Dual Gap Motor Design
* Surround Clamping Ring
* Spider Clamping Ring with Integrated Speaker Terminals
* Axial Edge Surround System
* Field Replaceable Cone Assembly
Mounting Diameter
13.125" (333.4 mm)
Mounting Depth
8" (203.2 mm)
33 lbs. (14.97 kg)
Bør vel hentes pga av vekten.Kan hentes i Trøndelag..
8000 kr,-
