Mr.TransAm Skrevet Mai 30, 2006 Rapporter Share Skrevet Mai 30, 2006 Er det i det hele tatt mulig å ta en wheelie med 220 hest? Engine: 1978 400c.i. rated at 220hp. To compete in the GT/GA class the 400 utilizes a pair of 6X heads. Its designed for a compression ratio of 8.9:1, which is the max allowable by NHRA rules for this class. Drivetrain: unknown Body & Interior: The car weighs in at 3305lbs which is the required legal weight for its class. Best quarter mile time: 10.17 @ 130mph *Note: This Firebird was not owned by RRE nor did it have an RRE built engine when it won the '96 Superstock Championship. Ganske imponerende 1/4 mil og Siter 1984 Recaro T/A 350 X - 1982 Recaro T/A X - 1984 Chevy G20 X - 1969 Custom Beetle Lenke til kommentar Del på andre sider More sharing options...
T/A 455 Skrevet Mai 30, 2006 Rapporter Share Skrevet Mai 30, 2006 Er det i det hele tatt mulig å ta en wheelie med 220 hest? Engine: 1978 400c.i. rated at 220hp. To compete in the GT/GA class the 400 utilizes a pair of 6X heads. Its designed for a compression ratio of 8.9:1, which is the max allowable by NHRA rules for this class. Drivetrain: unknown Body & Interior: The car weighs in at 3305lbs which is the required legal weight for its class. Best quarter mile time: 10.17 @ 130mph *Note: This Firebird was not owned by RRE nor did it have an RRE built engine when it won the '96 Superstock Championship. Ganske imponerende 1/4 mil og Den motoren er en Pontiac 400 med lavcomp topper med 99cc forbrenningsrom. Så de er enten planet mye eller dome stempel. At en 400cid har 220hk orginalt i 1978 er riktig, men den der er da ikke orginal. Er nok over 500hk og en solid mengde dreimoment i den motoren der. Siter 1966 Pontiac Catalina 421 Tri Power 1974 Pontiac Catalina Safari Wagon 1975 Pontiac Trans AM prosjekt 1977 Pontiac Catalina Safari Wagon Lenke til kommentar Del på andre sider More sharing options...
GreenMile Skrevet Mai 30, 2006 Rapporter Share Skrevet Mai 30, 2006 Og 10,17 på kvartmila med 220 hk.... Siter There's no replacement for displacement Lenke til kommentar Del på andre sider More sharing options...
T/A 455 Skrevet Mai 30, 2006 Rapporter Share Skrevet Mai 30, 2006 Engine: 1978 400c.i. rated at 220hp. En riktig oversettelse av det der vill være: 1978 400cid opgitt fra fabrikk til 220hk. Så nei, en 220hks motor klarer ikke å dra bile gjennom 1/4 mila på 10sec, dra en tur å se på dragracing så skjønner du fort at det er teknisk umulig. Om bilen hadde veid 300kg så kanskje... Siter 1966 Pontiac Catalina 421 Tri Power 1974 Pontiac Catalina Safari Wagon 1975 Pontiac Trans AM prosjekt 1977 Pontiac Catalina Safari Wagon Lenke til kommentar Del på andre sider More sharing options...
Mr.TransAm Skrevet Mai 30, 2006 Forfatter Rapporter Share Skrevet Mai 30, 2006 Regnet med et slikt svar ja...så ikke logikken i den teksten da jeg leste den første gang. Siter 1984 Recaro T/A 350 X - 1982 Recaro T/A X - 1984 Chevy G20 X - 1969 Custom Beetle Lenke til kommentar Del på andre sider More sharing options...
X-Cell Skrevet Mai 30, 2006 Rapporter Share Skrevet Mai 30, 2006 den er nok ikke orginal nei.. :) men med di lugga der på bakhjula så griper det jo tak.. så.. ;) 78'n hadde vel ikke 220hk orginalt? det var vel 400 N/A som hadde 220hk.. vanlig 400 hadde vel bare 170-180hk.. var nå bare 180hk i min 79mod... men så hadde man fiksa litt på den så den lå på ca 240hk.. 77mod'n jeg hadde sto det en 350 chevy i.. den var ca 350hk.. Siter Naf ungdoms kontakt avd. Narvik og Omegn OPC Driver Lenke til kommentar Del på andre sider More sharing options...
T/A 455 Skrevet Mai 30, 2006 Rapporter Share Skrevet Mai 30, 2006 Trans am med WS6 pakken hadde 220hk. Standard med automatgir 180hk Med manuelt gir 200hk Med olds 403, 185hk Siter 1966 Pontiac Catalina 421 Tri Power 1974 Pontiac Catalina Safari Wagon 1975 Pontiac Trans AM prosjekt 1977 Pontiac Catalina Safari Wagon Lenke til kommentar Del på andre sider More sharing options...
DiNGo Skrevet Mai 31, 2006 Rapporter Share Skrevet Mai 31, 2006 Sørgelig lite hester det er kontra størrelse.. Men momentet er der og potensialet er der HVERTfall! Min 77' Trans-Am med automat var en 400 c.i.d og jeg trodde den hadde 220 hk.. Men kansje den bare hadde 185 hk ? Dro ikke skinkene langt innover i veloursetene når man pusha stålet til golvet akuratt... :P Motorblokka var rød.. Men kansje lakkert. Motorkoden var Z. Siter Galant 2002 comfort sedan Lenke til kommentar Del på andre sider More sharing options...
T/A 455 Skrevet Mai 31, 2006 Rapporter Share Skrevet Mai 31, 2006 Sørgelig lite hester det er kontra størrelse..Men momentet er der og potensialet er der HVERTfall! Min 77' Trans-Am med automat var en 400 c.i.d og jeg trodde den hadde 220 hk.. Men kansje den bare hadde 185 hk ? Dro ikke skinkene langt innover i veloursetene når man pusha stålet til golvet akuratt... :P Motorblokka var rød.. Men kansje lakkert. Motorkoden var Z. Det var altså en Pontiac 400cid? da har den enten 180,200 eller 220hk. Oldsmobil 403 motoren hadde 185hk Antar du hadde første gir som gikk til over 100km/t... Da må man ha en trimma høycomp 400 for at det skal bli morsomt, eller en trimma 455 for at det skal bli hysterisk morsomt :) Siter 1966 Pontiac Catalina 421 Tri Power 1974 Pontiac Catalina Safari Wagon 1975 Pontiac Trans AM prosjekt 1977 Pontiac Catalina Safari Wagon Lenke til kommentar Del på andre sider More sharing options...
Blackbird Skrevet Mai 31, 2006 Rapporter Share Skrevet Mai 31, 2006 Z var Pontiac 400 WS6 har ingenting med motoren å gjøre det er kun bremser og understell. Min WS6 har 185 hk. Det står desverre mye feil forskjellige plasser ang effekt på desse. Dette er vurdert utifra GM`s originallitteratur. Correct me if I`m wrong. Siter -71 Vista Cruiser -79 Trans Am Blackbird -96 Suburban 5,7 Vortech X:G20-K5-S10-Z28-GTA-Astro-Caprice-Century-Regal-Mustang-Dart-Ramcharger+++ Lenke til kommentar Del på andre sider More sharing options...
T/A 455 Skrevet Mai 31, 2006 Rapporter Share Skrevet Mai 31, 2006 Z var Pontiac 400WS6 har ingenting med motoren å gjøre det er kun bremser og understell. Min WS6 har 185 hk. Det står desverre mye feil forskjellige plasser ang effekt på desse. Dette er vurdert utifra GM`s originallitteratur. Correct me if I`m wrong. Vill tipe grunnen til at din bil har en Olds 403 på 185 hk er at det er en Calefornia bil. i resten av USA var det vanlig med Pontiac 400. I Calefornia vill bilen ha Olds 403 uavhengig av om det er WS6 eller ikke, ergo kun 185hk i WS6. Forøvrig har jeg kun sjekket effekt på 1978 WS6, kan jo være annerledes i 1979. Siter 1966 Pontiac Catalina 421 Tri Power 1974 Pontiac Catalina Safari Wagon 1975 Pontiac Trans AM prosjekt 1977 Pontiac Catalina Safari Wagon Lenke til kommentar Del på andre sider More sharing options...
V8power Skrevet Mai 31, 2006 Rapporter Share Skrevet Mai 31, 2006 400 motoren var vel vekke i 79.403 oldsen var den største. Siter 1967 Buick Elektra Limited 4dht prosjekt 1968 Oldsmobile 98 Convertible 1968 Buick Skylark 2dht prosjekt 1969 Dodge Charger 440 1978 Chevrolet Corvette Lenke til kommentar Del på andre sider More sharing options...
Krishell Skrevet Mai 31, 2006 Rapporter Share Skrevet Mai 31, 2006 jeg har hatt wheelie med 150hk ;) bmw 3 serier med slitne dempere forran og bak ( bare vann i dem :P ). da fikk man dratt på bakhjulet med litt jukking. dro langt også. Litt spesielt syn ut av skolen. sorry OT , men måtte bare Siter Lenke til kommentar Del på andre sider More sharing options...
T/A 455 Skrevet Mai 31, 2006 Rapporter Share Skrevet Mai 31, 2006 400 motoren var vel vekke i 79.403 oldsen var den største. Har sjekket opp litt. I 1979 var ca 90 000 av den totale transam produksjonen på 116 000 biler med Olds 403, ca 8000 biler hadde Pontiac 400 Alle Pontiac 400cid motorene hadde 225hk, så bilen klarte vistnok 0-100på 6,7sec og 1/4 mila på ca 15,5. Bilene med Pontiac motor hadde navnet T/A 6.6 Alle hadde manuelt gir og Oldsmobil 403 hadde 185hk. Siter 1966 Pontiac Catalina 421 Tri Power 1974 Pontiac Catalina Safari Wagon 1975 Pontiac Trans AM prosjekt 1977 Pontiac Catalina Safari Wagon Lenke til kommentar Del på andre sider More sharing options...
Mr.TransAm Skrevet Juni 1, 2006 Forfatter Rapporter Share Skrevet Juni 1, 2006 http://transamworld.com/fbird-history-php2.php <---------Les alt om prod tall, motorstørrelser osv osv osv... Siter 1984 Recaro T/A 350 X - 1982 Recaro T/A X - 1984 Chevy G20 X - 1969 Custom Beetle Lenke til kommentar Del på andre sider More sharing options...
