Monoblokk ønskes
audiman
Er det 1000.2 du har du med helixen?
Å den orion forsterkern, har du noe link til en side med denne på ?
Hifonic: info å pris osv på forsterkern?
Skal drive en kicker solobaric 15" L7..:
Key Features:
aluminum deposit cone
non-resonant aluminum basket
Santoprene rubber surround
dual 4-ohm voice coils for wiring flexibility
frequency response 20-100 Hz
power range 150-1000 watts RMS
peak power handling 2,000 watts
Sensitivity (dB 1W/1M) 88.5
Frequency Response (HZ) 18-100
Mounting Depth (IN., CM) 8-3/16, 20.8
Mounting Cutout, Square (IN., CM) 14-1/16, 35.7
Min Rec Sealed Box Vol (CU. FT., LITERS) 1.5, 42.5
Max Rec Sealed Box Vol (CU. FT., LITERS) 6.0, 169.9
Min Rec Vented Box Vol* (CU. FT., LITERS) 3.0, 85.0
Max Rec Vented Box Vol* (CU. FT., LITERS) 6.0, 169.9
pi21/pøl i Brei
