Bilstero selges (Kicker\JBL)
Kicker KX300.4
strøken og lite brukt
- Kicker 4 Channel 75 Watt Amplifier
- 2-, 3-, 4-channel or Tri-Way output
- 38 watts RMS x 4 at 4 ohms
- 75 watts x 4 at 2 ohms
- 150 watts x 2 in bridged mode
- Speaker- and preamp-level inputs
- Front and rear high-pass/low-pass crossovers (variable 50-200 Hz, 12 dB per octave)
- Front/rear bass boost (0-18 dB at 40 Hz)
- Frequency response 20-20,000 Hz
- Requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
- Unregulated Class A/B power supply offers a significant increase in power at 2 ohms
nypris 4995,-
selges HBO 2000,-
Kicker KX800.2
støken og lite brukt forsterker
- stereo, bridged mono or Tri-Way output
- 200 watts RMS x 2 at 4 ohms
- 400 watts x 2 at 2 ohms
- 800 watts x 1 in bridged mode
- speaker- and preamp-level inputs
- preamp outputs (pass full-range signal to another amp)
- high-pass/low-pass crossover (variable 50-200 Hz, 12 dB per octave)
- bass boost (0-18 dB at 40 Hz)
- remote gain controller with 20-foot cable
- frequency response 20-20,000 Hz
- requires 2-gauge power and ground leads — wiring and hardware not included with amplifier
- unregulated Class A/B power supply offers a significant increase in power at 2 ohms
nypris 8995,-
selges HBO 4000,-
2 stk JBL GT4-12 i kasse selges
SPECIFICATIONS
General
Frequency Response 28Hz - 450Hz
Sensitivity 93dB
Impedance 4 Ohms
Voice-Coil Diameter 50mm
Cut-Out Diameter 283mm
Mounting Depth 161mm
Overall Diameter 311mm
Vas 100.45 liter
Qts 0.43
Fs 24.75Hz
Qes 0.46
Qms 6.46
både subber og kasse er strøkne.. spiller utrolig bra. lite brukt
har kvittering på både subber og kasse
spilte 128,5 db i en Golf 3 (målt av MaxPower)
mål kasse h:40cm b:83cm d:43cm
nypris pr sub 1295,-
nypris kasse 1600,-
selges samlet HBO 2000,-
genscrap.aspx?id=5509
genscrap.aspx?id=5510
Stinger 1.2 Farad Expert Capacitor
New Octagon shaped 1.2 farad capacitor features 20-volt nominal / 24-volt surge ratings, real neon accent tube, strobe affect LED array, and 4 digit bright blue voltmeter display.
Black chrome housing with embossed Expert Hex badge.
nypris 3495,-
selges HBO 1500,-
er ikke så ofte inne her...
så RING eller send en SMS om dere lurer på noe
Stian 92201562
Opel Vectra 2000 16v Turbo
Opel Calibra 2,5 v6
Opel Calibra 16v
VW Golf 2 1,8
VW Golf 2 1,8 Sport
Chevrolet Beauville 6.2
Oki da. kjøper den for 2000:)
2000,- + frakt? er din om jeg ikke får noe høyrere bud innen fredag..
subbene koster nye 1295,- på bilradiospesialisten der hvor de er kjøpt.
ville helst solgt de samlet med kasse.
Opel Calibra 2,5 v6
Opel Calibra 16v
VW Golf 2 1,8
VW Golf 2 1,8 Sport
jepp. du får bare si fra:D
-Bmw 320Turbo
x *Nissan 200sx rs13 sterkt modifisert:)
x *Bmw E30
x *90 Mod Crx V-tec :D
Det høres jo bra ut. Da kommer du innom på mandag og kjøper forsterkerene mine ;)
ja det er velstand det Stig ;)
kommer innom å handler så fort jeg har fått peng for anlegget. var snakk om en uke eller no
:disco
Opel Calibra 2,5 v6
Opel Calibra 16v
VW Golf 2 1,8
VW Golf 2 1,8 Sport
