Ny Bmw!
Ostby
New three-wheeler launched by BMW
07/23/2003
For the first time since the unveiling of the legendary Isetta in 1955, BMW is once again launching a head-turning three-wheeler. This time it's not a ground breaking new car, but an innovative scooter.
Created by BMW Designworks USA, the SlideCarver is made of rugged and light forged aluminium. Tight cornering, excellent handling and supreme stopping power is achieved without compromising comfort and stability - just what you would expect from a BMW.
The SlideCarver's board is made of fibre-glass reinforced polyamide and aluminium with high load-bearing strength. Exceptional handling is achieved using a double-joint swinging support component taken from the running gear of the E39 BMW 5-Series. This ensures that when steering, the board of the SlideCarver pivots in the direction of the turn, improving the rider's centre of balance. Handlebar mounted brake levers are linked to a finely adjustable hydraulic twin-disc brake system on its rear wheels. The brake cables are discreetly located within the tube of the handlebars giving a more streamlined appearance and protection from weather and scuffing. Front wheel suspension also provides greater ride comfort.
The SlideCarver is easy to transport. It incorporates a patented one-handed folding mechanism, consisting of a folding joint at the base of a telescopic handle bar that connects to the board, allowing it to fold up and fit into the boot of a car. Unfolding in a matter of seconds, it requires no additional tools.
The SlideCarver comes with high quality, maintenance free wheel bearings fitted as standard and low profile polyurethane tyres that even have wear indicators to show when new tyres need to be fitted. The two-part aluminium rim can be easily disassembled to allow the replacement of the tyre running surface.
The SlideCarver is made exclusively for BMW and costs £465.00. It's available now, and can be ordered from any BMW dealer.
SlideCarver dimensions:
Length 77cm
Width 50cm
Height Approx 100cm (when steering)
Wheel base 66cm
Weight 12kg
Moped
x EVO VI TME
x Ducati 748r Solgt =((
