nicoloco Skrevet September 7, 2006 Rapporter Share Skrevet September 7, 2006 Her kan du lese anmeldelse av forsterkeren Denne forsterkeren tåler 1 ohm's last, jeg vil derimot ikke anbefale lavere enn 2 ohm last. Da yter den ca. 1x700watt. Med disse to i samme bagasjerom har du 3 store problemer: 1. Du har nesten ingen plass igjen til subber 2. Du må bruke MYE penger i subber for å utnytte max effekt 3. Du kommer til å slite med strømmen Pris: Kom med bud, jeg vurderer alt. :) Dette er forsterkere for de som vet hva de vil ha, resten kan ta pengene og kjøpe en helt ny digitalforsterker til nesten samme prisen. :) Frequency Response (4 Ohm IHF Load 20Hz to 20 kHz, 1 kHz Ref.): +0 dB, -0.2 dBL/R channel error, max deviation 20 Hz to 20 kHz: 0.2 dB Phase Response (4-ohm IHF Load 20Hz to 20kHz 1kHz Ref.): +6.5 degrees, -12.3 degrees Signal-to-Noise Ratio (Below Rated Output, “A” weighted): -118.2 dB Distortion at Rated Output @ 1 kHz: 0.25% @ 900 watts Output Power(resistive) minimum output 20 Hz to 20 kHz @ 1%THD+N (all channels driven into 4 ohms): 274 watts x 2 @ 14 volts; 225 watts x 2 @ 12.8 volts; 140 watts x 2 @ 10.5 volts Output Power (resistive) minimum output 20 Hz to 20 kHz @ 1%THD+N (all channels driven into 2 ohms): 455 watts x 2 @ 14 volts 371 watts x 2 @ 12.8 volts; 227 watts x 2 @ 10.5 volts Output Power (4-ohm IHF Reactive Load @ 60 Hz to 1% THD+N): 995 watts Crosstalk (Referenced to Rated Output, 20 Hz to 20 kHz): -52 dB Damping Factor @ 100 Hz, 2 ohms: 348 Voltage for Rated Output: 215mV to 4.5 volts Idle Current Draw: 1.5 amps Current Draw @ 1/3 Maximum Power: 63.5 amps @ 316 watts Efficiency @ 1/3 Maximum Power: 36% Power-Up Noise: -3.7 dB SPL Power-Down Noise: 22 dB SPL Ved salg via forumet går 5% av kjøpesummen til Bilforumet.net Siter BMW e36 318ia Nissan Primera 2.0GT Lexus IS 200 TIC solgt Renault Laguna 2.0 RT solgt If I gave a shit, you'd be the first to get it! Lenke til kommentar Del på andre sider More sharing options...
Snow4Fun Skrevet September 10, 2006 Rapporter Share Skrevet September 10, 2006 hva er måla på forsterkerene? Siter 88 Honda Prelude 2.0L 16V doch 150hk 96 Audi A4 1,8T Lenke til kommentar Del på andre sider More sharing options...
nicoloco Skrevet September 10, 2006 Forfatter Rapporter Share Skrevet September 10, 2006 Aner ikke.. den er stor.. :) Nærmere 1 meter lang? :) Siter BMW e36 318ia Nissan Primera 2.0GT Lexus IS 200 TIC solgt Renault Laguna 2.0 RT solgt If I gave a shit, you'd be the first to get it! Lenke til kommentar Del på andre sider More sharing options...
Drinkmix Skrevet September 11, 2006 Rapporter Share Skrevet September 11, 2006 gode forsterkere. men alt avhenger av pris. hva har du tenkt deg? Siter Lenke til kommentar Del på andre sider More sharing options...
