Knekte ventilfjører.
Er vel kun her de er behov for slike.
Selger et set med dobble ventilfjører. Aldri vert brukt. og ligger i orginal embalasje. Fjørene er av typen comp cams.
Number of Springs Per Valve: Dual
Outside Diameter of Outer Spring (in): 1.535 in.
Coil Bind Height (in): 1.180 in.
Damper Spring Included: Yes
Spring Rate (lbs/in): 437 lbs./in.
Inside Diameter of Outer Spring (in): 1.125 in.
Inside Diameter of Inner Spring (in): 0.755 in.
Valve Spring Style: Standard
Coated: No
Quantity: Sold as a set of 16.
Valve Springs, Dual, 1.535 in. Outside Diameter, 437 lbs./in. Rate, 1.180 in. Coil Bind Height, Set of 16
Produkt nr. comp cams 929-16
Vist noen har dobble ventil fjører å selge, so fortell hva du har. Kan muligens vere inntresert:)
-97 BMW 525tds Touring (E-39)
-80 Chevy Cparice stv SBC350-TH350
-88 Ford Escort Cab 1.6xr3i
-68 Chevelle 2D HT BBC439-TH400
-81 Opel Commodore 2.5E
