Rotrex Skrevet Oktober 13, 2006 Rapporter Share Skrevet Oktober 13, 2006 Selges: 2 stk Alpine Type X SWX-1042D 3000W Peak 1000W RMS [subwoofer Type-X Features] • Frequency Response: 22Hz – 500Hz • Designed and Engineered in the USA • Hidden Screw Gasket • Gold Plated Insert Terminal Block with VC Connection Jumpers • One-Sided Terminal Layout • Massive Triple Stacked Strontium Magnets • FEA Optimized High Excursion Injected Santoprene® Multi-Roll Surround • FEA Optimized Mirrored Progressive Nomex® Spiders with Integrated Tinsel Leads • FEA Optimized CRC T-Drive Motor Structure with Copper Shorting Sleeve & Heat Transfer Technology • Multi-Stage Ventilation System (Dual Flare Pole, Spider Plateau & Frame Leg Venting, Cone/VC Junction Venting) • Integrated Spider Landing and Heat Transfer Plate • Dual Voice Coil Design, 4-Layer 220°C High Temp Wire with Inner/Outer Winding on Twin-Wall Brass Former • Custom Cast Aluminum Frame • Carbon Fiber/Aluminum Honeycomb Parabolic Cone • RMS Power 1000W • Peak Power 3000W Selges grunnet skade på bilen som disse skulle monteres i, de er ubrukt og ligger i orginalembalasjen. Mer info om elementene: http://www.alpine-europe.com/content/english/a500.det.SWX-1042D_10%22-25cm-Subwoofer-4Ohm-%2B-4Ohm.htm Selges for kun 4000kr pr stk bud ønskes. Siter Lenke til kommentar Del på andre sider More sharing options...
Tufte & toyota Skrevet Oktober 13, 2006 Rapporter Share Skrevet Oktober 13, 2006 Rotrex skrev: Selges: 2 stk Alpine Type X SWX-1042D 3000W Peak 1000W RMS [subwoofer Type-X Features] • Frequency Response: 22Hz – 500Hz • Designed and Engineered in the USA • Hidden Screw Gasket • Gold Plated Insert Terminal Block with VC Connection Jumpers • One-Sided Terminal Layout • Massive Triple Stacked Strontium Magnets • FEA Optimized High Excursion Injected Santoprene® Multi-Roll Surround • FEA Optimized Mirrored Progressive Nomex® Spiders with Integrated Tinsel Leads • FEA Optimized CRC T-Drive Motor Structure with Copper Shorting Sleeve & Heat Transfer Technology • Multi-Stage Ventilation System (Dual Flare Pole, Spider Plateau & Frame Leg Venting, Cone/VC Junction Venting) • Integrated Spider Landing and Heat Transfer Plate • Dual Voice Coil Design, 4-Layer 220°C High Temp Wire with Inner/Outer Winding on Twin-Wall Brass Former • Custom Cast Aluminum Frame • Carbon Fiber/Aluminum Honeycomb Parabolic Cone • RMS Power 1000W • Peak Power 3000W Selges grunnet skade på bilen som disse skulle monteres i, de er ubrukt og ligger i orginalembalasjen. Mer info om elementene: http://www.alpine-europe.com/content/english/a500.det.SWX-1042D_10%22-25cm-Subwoofer-4Ohm-%2B-4Ohm.htm Selges for kun 4000kr pr stk bud ønskes. har en stk ubrukt jeg også..... 97527116 bud ønskes også her..... da har jo eventuelt en kjøper mulighet til å bruke 2stk. uansett så ønskes lykk til med salget, samt at du fikk en "gratis" bump av meg...he,he,he Siter Lenke til kommentar Del på andre sider More sharing options...
Fab Skrevet Oktober 13, 2006 Rapporter Share Skrevet Oktober 13, 2006 Rotrex har faktisk 2stk til salgs, så da kan en evt. kjøper kjøpe 3stk. hehe :) Siter - Nissan 200sx s13 92mod, sort - Toyota Celica 88mod GT - SOLGT - Golf III 95 mod. på 18" - SOLGT Lenke til kommentar Del på andre sider More sharing options...
