Bambo Skrevet Oktober 18, 2006 Rapporter Share Skrevet Oktober 18, 2006 Subben er så å si helt ny. Kun spilt inn å brukt ca 10 timer etter det. Selges grunnet salg av bilen den var bygd i.. Specs: W12GTI 12" Differential Drive® Design Subwoofer If you are in search of the ultimate woofer, this is it! JBL has leveraged all engineering resources to develop quite simply the best subwoofer money can buy. Symmetrical Field Geometry ensures linear cone travel and low distortion at virtually any level by creating a uniform magnetic field around the coil. Die-Cast basket. • Suggested Retail Price: $599.00 • Differential Drive® Design (DDD) motor • Die-cast vented basket • Kevlar®-impregnated paper woofer cone • Nitrile-butylene surround • Power handling RMS: 700 watts • Power handling Peak: 4,000 watts • Cut-out diameter: 11" • Mounting depth: 10-1/4" • Sensitivity: 91dB • Dual 6-ohm voice coils Siter "Having a 9 second vag is like coming out of the closet: At first you surprise all your friends, but in the end you're still gay" *Omega B1 TD. *Rekord C *Vectra turbo. *Omega B2 stv. Håvard. TLF: 41408822 Lenke til kommentar Del på andre sider More sharing options...
Bambo Skrevet Oktober 18, 2006 Forfatter Rapporter Share Skrevet Oktober 18, 2006 Koster 6989 ny i butikk til full pris. Selges hb. Men forbeholder meg retten til å ikke selge om jeg ikke er fornøyd med prisen. Siter "Having a 9 second vag is like coming out of the closet: At first you surprise all your friends, but in the end you're still gay" *Omega B1 TD. *Rekord C *Vectra turbo. *Omega B2 stv. Håvard. TLF: 41408822 Lenke til kommentar Del på andre sider More sharing options...
Bambo Skrevet Oktober 20, 2006 Forfatter Rapporter Share Skrevet Oktober 20, 2006 opp Siter "Having a 9 second vag is like coming out of the closet: At first you surprise all your friends, but in the end you're still gay" *Omega B1 TD. *Rekord C *Vectra turbo. *Omega B2 stv. Håvard. TLF: 41408822 Lenke til kommentar Del på andre sider More sharing options...
