351RS: Granada RSV8 v2.0 , evighetsprosjektet. I år må det vel bli EFI vel?
351RS
  • Svar 1.2k
  • 4 weeks later...
Motoren blir bygd av Coast High Performance som har bygd tusenvis av strokermotorer, har vært i drøssevis av artikler i blader og er leverandør av strokerkits til eks. Fordstrokers.com.
"The Pro Street Series of CHP Long Blocks are high performance street/strip engines. We rate the Pro Street Series as being perfect for applications up to 800 horsepower. They provide an excellent level of reliability in a brutal environment.
CHP PRO STREET Long Blocks Include:
Probe Industries SRS Forged Pistons (2618-T61)
Probe Industries Forged 4340 Steel Crankshaft
Probe Industries H-Beam Connecting Rods
Fully Machined and Inspected Factory Block
Airflow Research Cylinder Heads (Modular 4.6 models have Patriot Performance heads)
Scorpion Performance Rocker Arms
Comp Cams "Xtreme Energy" Hydraulic Roller Camshaft
Elgin Industries Hydraulic Roller Lifters
Manley 4130 Steel Pushrods
Cloyes Street True Roller Timing Gear Set
Clevite Perfect Circle Rings
Clevite 77 Main P-Bearings
Clevite 77 Rod P-Bearings
Fel-Pro PermaTorqueMLS Head Gaskets
Balanced
Blueprinted
Assembled to exacting tolerances and Inspected by CHP Master Engine Builders.
Technical Specs :
Item Code: 14802-PS-F408W-LB
Vendor Name: Coast High Performance
Product Type: Long Block
Product Model: Pro-Street
Engine Family: FORD-LINCOLN-MERCURY - Small Block 351 Windsor Based V8
Engine Displacement (cu.in.): 408
Balanced: Yes
Engine Balance Type: External-28oz
Blueprinted: Yes
Compression Ratio: 9.20 : 1
Engine Stroke (in): 4.000
Engine Bore (in): 4.030
Piston Manufacturer: Probe Industries
Piston Part Number: 14802-030
Piston Material: 2618-t61 Forged Aluminum
Piston Top Type: Reverse Dome
Piston Head Volume (CC): -33.8cc
Wrist Pin Material: 8620 Steel
Crankshaft Vendor: Probe Industries
Crankshaft Part Number: 10055
Crankshaft Material: Forged 4340 Steel
Connecting Rod Vendor: Probe Industries
Connecting Rod Part Number: 10081
Connecting Rod Material: Forged 4340 Steel
Connecting Rod Length (in): 6.200
Connecting Rod Type: H-Beam
Block Manufacturer: Ford
Block Part Number: 61810B-HR
Block Material: Cast Iron
Block Type: OEM 351W Roller 2-Bolt - 1 pc RMS
Cylinder Head Manufacturer: Airflow Research
Cylinder Head Style: Race Heads
Intake Runner Volume (cc): 205cc
Combustion Chamber Volume (cc): 58cc
Head Gasket: Fel-Pro PermaTorqueMLS - NASCAR issue
Rocker System Manufacturer: Scorpion Performance
Rocker System Type: Stud Mount - 1.6 Ratio
Camshaft Manufacturer: Comp Cams
Camshaft Type: "Xtreme Energy" Hydraulic Roller
Valve Lift (Intake/Exhaust): .565/.574
Duration (@ .050 Lift): 232/240
Lobe Separation (degrees): 112
Notes Components rated to 800 Horsepower"
Toppene er da prod.nr.: 1450, og kammen blir pga. planer om boost erstattet med Comp cams nr.: 35-556-8. Dette er en Nitrous/light blower kam, som har følgende data:
Cam Style Hydraulic roller tappet
Basic Operating RPM Range 2,200-6,200
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 236
Duration at 050 inch Lift 224 int./236 exh.
Advertised Intake Duration 274
Advertised Exhaust Duration 286
Advertised Duration 274 int./286 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.555 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.570 in.
Valve Lift with Factory Rocker Arm Ratio 0.555 int./0.570 exh. lift
Lobe Separation (degrees) 114
Grind Number FW NX274HR-14
Planer om Boost er seff åsså grunnen til den lave kompen.
Når jeg la inn motor dataene i Comp Cams simulator program: Cam Quest, kom denne kammen opp som første valg, og ifølge dette programmet ga den faktisk åsså bedre effekt som NA motor.
Denne kammen ga åsså temmelig flotte kurver i Desktop Dyno, med bare 10 lbs boost.
No subsitute for cubic inches !
Prosjekttråd :Granada 351RS
Saker!
Ja, skulle tro det. Og ikke minst holdbart.
Blir rått!
Hva havner effekten på?
Blei så mye tall og engelsk at jeg blei helt forvirra:P
Nå blir jo motoren i første omgang kjørt med det innsug, gasser og resten jeg allerede har, så tenker vi sier 450, men det passer fint, så blir det en mykere overgang, hehe.
Ojoj, detaljert ska'n si... :D
Pris på dette for at den sitter i Grænnis'n?
100000kr-klassen??
Det er i utgangspunktet en ferdig Cratemotor, denne:
http://www.coasthigh.com/ProductDetails.as...;Show=TechSpecs
Men siden jeg har en komplett motor, trenger jeg bare en longblock, denne:
http://www.coasthigh.com/product-p/14802-ps-f408w-lb.htm
Så bruker jeg bare det eksterne som jeg allerede har. Om det blir sprut etterhvert, må jo eks. innsug og gasser byttes likevel, så ser ikke poenget med å kjøpe dette nå. Pluss at jeg sparer penger seff, hehe.
Ok for de som er litt interessert i å se det teoretisk, her er litt å tygge på. Selv om den ikke er fasiten, gir den en rimelig grei peikepinn.
Her er først og fremst min nåværende 351W motor sammenlignet med CHP sin 408W. Tiltross for den lave kompen yter denne rundt 520 hk og straks over 500 ft-lbs(680 Nm). Med optimal (for NA) komp ville tallene vært 20-30 høyere (helfargede linjer =351W og med blå kryss= 408W).
(dere kan se de virkelige talla i Cratemotor linken lengre opp i innlegget her)
Her er kammen byttet mot nitrous/blower kammen. Toppeffekten her blir mindre: 490, men den har opptil 40 Nm mer fra 2000 0/min: ca 560 Nm. Skiftet der NA kammen tar over er ca 5000 varv, og ved 6000 har NA kammen altså over 30 hk mer(helfargede linjer= NA kam og med blå kryss= blower kam). PS: dette er fremdeles UTEN boost.
SÅ kan vi putte på litt tvangsluft. 10 psi, knappe 0,7 bar. (helfargede linjer= NA kam og med blå kryss= blower kam). Toppeffekten ligger her på rundt 830 hk og vridet på ca 830 ft-lbs(1125 Nm)
Men legg merke til vridet fra 2000 varv: 550ft-lbs, eller 740 Nm !! Ja det skulle være nok til å dra i gang et tog ja.
Her er tallene:
Ser det greit ut dere?
Har lest gjennom mer eller mindre hele tråden din de 2-3 siste dagene nå. Og jeg er IMPONERT. Tror ikke det er noen her på forumet som forklarer så godt å punktlig hva og hvorfor. Og samtidig gjør det veldig forståelig! All creds til deg! Og må jo bare si at dette har utviklet seg en god del siden du begynte med denne. Kan jo ikke si det er negativt :D
Kommer til og følge med her i fremtiden og kondolerer med motorras!
Ingenting er umulig for gud og bilmekanikere :D
Det er bare to typer bilister på veiene: idioter som kjører langsommere enn meg, og de svina som kjører fortere!
  • 2 months later...
