Ford Introduserer: FPV biler!
Sjekk disse a! Bilder og tekst er hentet fra et annet forum:
Introducing the Force 8
The Force 8 moves you with a 32 valve quad cam Boss V8, an engine comparable to Europe's best. The awe-inspiring Boss 290 is a powerplant unlike any ever built in this country and comes to life on Australia's only current V8 engine production line.
The Boss 290 was developed right here in Australia by Ford Performance Vehicles for our unique requirements and to meet the rising demands of a new breed of Aussie V8 drivers.
Its 5.4-litre capacity, 32 valves and double overhead camshafts per bank work in concert to produce 290 kilowatts of power and a phenomenal 520 Newton metres of torque. So not only is there free-revving top-end power but a wall of torque at low speeds as well. In combination with the tuned stainless steel exhaust system, it produces the trademark rumble that lets you know you're driving a real, blue-blooded Aussie V8. It has a quality that clearly communicates who exactly owns the road.
The Force 6
The Force 6 is powered by the same engine as the F6 Typhoon - a turbo charged 24 valve six with an amazing 550 Nm of torque.
The F6 270 Turbo. A 4-litre turbo-charged, intercooled, 24-valve double overhead cam six. The highest torque output of any production six ever built in Australia and one of the most powerful in the world. Through partnership with Prodrive and their mastery of turbo technology across F1 and World Rally, the development of our high performance turbo-charged FPV has changed performance cars forever. We created an engine with dramatically improved cooling and induction. The 50% larger (than XR6 Turbo) air-to-air intercooler and dual Ram Air system significantly reduces intake pressure into the turbo's compressor - allowing it to work more efficiently... and effectively.
The result. A fully engineered performance-driven power generator. Armed with double overhead camshafts and 4-valve aluminum cylinder heads, the F6 270 Turbo produces its maximum power of 270kW at 5250 rpm. However, the real story is torque. All 550Nm is on tap from just 2000 rpm and remaining constant all the way through to 4250 rpm.
At time of launch, the highest torque output of any production engine ever built in Australia. Even more staggering is the engine's ability to produce 80% of its maximum torque at 1500 rpm and over 98% at 1750 rpm. Total Performance meets the turbo.
Brakes
The power to stop you is provided by Performance Brembo 4 piston front brake calipers and single piston rear calipers. Cooling is enhanced with cross drilled brake rotors as standard. A Premium Brembo 6 piston front and 4 piston rear brake package is available as an option.
Performance Brakes
Up front, huge 355mm x 32mm cross drilled and slotted front rotors with Brembo 4 piston calipers and 328mm x 26mm cross drilled rear rotors with red single piston calipers and are standard on Force 6 and Force 8.
Premium Brakes
For the ultimate in stopping power choose the FPV Premium brake package, which consists of 355mm x 32mm cross drilled and slotted front rotors with Brembo 6 piston calipers and 330mm x 28mm cross cross drilled rear rotors with Brembo 4 piston calipers. Optional Force 6 and Force 8.
Brembo brakes are amongst the best brake packages in the world and are another example of FPV's commitment to Total Performance
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
X - 1969 Custom Beetle
Ford BF MK2 GT
The BF MkII GT more than lives up to the famous badge. It is the muscle car for the 21st century. With 290kWs of Boss quad cam V8 power and the choice of 6-speed manual gearbox or the no cost optional ZF 6 speed high torque automatic. The GT is second-to-none for outright handling and driver comfort in a 5 passenger Australian built performance sedan.
Like the GT legends of the past, its styling is impossible to ignore, incorporating the GT badge into the upper grille. The new retro-cool FPV side stripes and Boss 290 hood decal are options and a FPV dual exhaust system, Brembo front brakes and 19" alloy wheels are standard.
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
FPV BF Mk2 GT-P
You want more? The FPV GT-P has everything the GT has — and more. Same big Boss engine. Same exhilarating performance. Then you start to appreciate the differences. New GT-P 5-spoke 19" alloy wheels with machined face, 355mm × 32mm cross drilled 6 piston front and 330mm × 28mm cross drilled 4 piston rear Brembo brakes and rear parking sensors are standard. FPV stripes and hool decal are a no-cost option. Choose between the close ratio 6-speed manual gearbox or the no cost optional ZF 6-speed automatic. Aggressive front and rear styling features satin-alloy upper and lower grille mesh, bright finish side skirt flutes and FPV dual exhaust. It's hard to believe any car could look more purposeful than the GT-P. This does.
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
FPV BF MKII Pursuit
290 kW of quad cam V8 power. Supercar-inspired front end design, 19" GT alloy wheels, twin chrome tailpipes and Brembo front brakes are standard for the ultimate stopping power. Inside, there's plenty of room to move within the Pursuit Supercab. Settle into the contoured FPV Sports seats (driver's 4-way electrically adjustable) and view the FPV sports gauges featuring oil temperature and oil pressure readouts. Enjoy the Prestige 6 stack CD system and interior command centre, featuring TFT screen. For a V8 inspired look, optional FPV retro-style stripe package including the Boss 290 hood decal are available. Standard is an FPV soft tonneau cover with the option of an alloy Sports Bar. Also available is an optional hard tonneau with FPV rear spoiler or combination hard tonneau and Sports Bar. The new BF MkII Pursuit. Total Performance means business.
nitrane is offline Reply With Quote
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
FPV BF MkII Super Pursuit
The ultimate FPV Ute. Quad cam Boss V8 engine, new GT-P 5-spoke 19" alloy wheels with machined face, Traction Control, 355mm x 32mm cross drilled and slotted 6 piston front Brembo brakes with 328mm × 26mm cross drilled rear rotors with red single piston calipers. Close ratio 6-speed manual gearbox or the no cost optional ZF 6-speed automatic. Aggressive front styling features satin-alloy upper and lower grille mesh and bright finish fog lamp surrounds. FPV Performance seats in Le Mans cloth or the no cost option of leather. FPV instrumentation including sports gauges for oil temperature and oil pressure. Premium sound system featuring large TFT colour screen, dual zone climate control and 150 watt 6 stack CD system. The bold new design FPV BF MkII stripe package is a no-cost option. A hard tonneau with spoiler is standard with the option of an alloy Sports Bar.
Super Pursuit. Fully loaded.
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
The Mind-Blowing F6 Typhoon
Ford Performance Vehicles has set a new benchmark in the Australian high performance car segment with the mind blowing F6 Typhoon.
Delivering a staggering 550Nm of torque, the highest torque output of any Australian built production engine, and 270kW of power from the turbo-charged and intercooled 4.0 litre six-cylinder F6 270 Turbo engine. The F6 Typhoon offers world-class standards of space and grace, whilst maintaining FPV's class-leading safety and refinement package.
The F6 Typhoon further reinforces FPV's mantra of Total Performance.
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
The F6 Tornado
Turbo-charged, intercooled, twin overhead cam 4-litre engine, the F6 Tornado unleashes 550Nm of torque. The new F6 19" pewter-accent alloy wheels are standard, while the sinister 19" Dark Argent alloy wheels with machined outer rims are optional. Your choice of 6 speed close ratio manual or no cost optional ZF 6 speed high torque automatic. FPV cross drilled front Brembo brakes and Traction Control are standard. The F6 Tornado also features an FPV soft tonneau cover and the option of an alloy Sports Bar. Also available is an optional hard tonneau with FPV 3 pillar rear spoiler or combination hard tonneau and Sports Bar. The F6 grille design proudly displays the purposeful turbo intercooler, while the F6 Tornado supercab features contoured F6 Sports seats and an interior command centre featuring TFT screen, Prestige 6 stack CD system, plus FPV sports gauges for turbo boost and oil pressure. Optional is a Premium sound system and dual zone climate control with large TFT colour screen.
Her får man jo noe for alle.
Tviler på at disse bilene blir lansert i Norge. lenge vært snakk om at SUT (Sport-utility-truck) skal komme. Og dette er Fords foreløpige modeller beregnet for det australske markedet.
Syntes hvertfall dette er noe av det sprekeste som har blitt lansert som normale biler.
Hva syntes folket?
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
Blir nok bare lansert i Australia de der desverre! :(
Noen ganger skjønner jeg bare ikke hva Ford tenker med? De har jo lenge slitt i det internasjonale markedet, og her kommer de med noen modeller som kan fint konkurrere med alle bilene som danker de ut om dagen. Men neeeeeei, "vi plasserer de på en øy langt uti helvete der ingen får tak i dem".... herregud
1984 Recaro T/A 350
X - 1982 Recaro T/A
X - 1984 Chevy G20
Får sånne biler kan jeg med GLEDE faktisk flytte til australia... Ble kåt nå jeg, de bilene var porno så det HOLDT!
1988 Golf II aka. Helene
Tollak: "Føler at håret mitt har begynt og bli langt nå"
Øge: "Kunne vært lengre..."
Tollak: "Å?"
Øge: "Hvis du hadde spart lengre, hadde håret ditt blitt lengre"
