Complete polished Cup 3-piece in 8.5+10x17"
Fidrio
RH ZW1 in 8.5+10x17 !! nearly perfect !!
Here you can get some beautiful RH-Wheels in really shining conditions !!
The size is
8.5 x 17" offset 53 (without orig. RH-Adapter)
10 x 17" offset 35 (without orig. RH-Adapter)
Other sizes are available, 9 or 9.5 x 17" for example !!
Also possible with golden screws or only with chrom or stainless screws.
Normaly they will fit all cars with 5 bolt pattern. You only have to use the right Adapters. This Adapters are begining with 20 mm and the biggest one will be 45 mm. For 5/112 you can also use plates with only 5.mm or 10 mm. If you want more informations about this Adaptersystems please take a look to the homepage of
http://www.rh-alurad.de/
This set is new polished at the centers and also at the outer rims and they
are shining really bright. After this work which was done by a specilised tuner
here in Germany the wheels were not used again !!
The screws are high-grade-steel with original gold over it.
Shipping to Norway will not be a probleme and would not be so expensive.
I will take original parcels of the wheels for transporting to you, so the fresh
polished wheels can´t get any scratches or damages. I think this set looks better than new :m'm:
This set was prooved and they are absolutly round !!!
Price should be 13700 NOK incl. shipping and incl. all equipment like bolts, centercaps and Adapters for your car.
Greetings by
Fidrio
  • 1 month later...
  • 2 months later...
The size is
Greetings by
Fidrio
up
