siggi321 Skrevet Mars 18, 2007 Rapporter Share Skrevet Mars 18, 2007 hva heter den russiske siden du fant ut alt om bilen?:) Siter praise the lowered:P Lenke til kommentar Del på andre sider More sharing options...
mbfreak Skrevet Mars 18, 2007 Rapporter Share Skrevet Mars 18, 2007 http://www.mbclub.ru/mb/vin/?lng=eng Siter Masse mb deler selges, ta kontakt. Lenke til kommentar Del på andre sider More sharing options...
viper Skrevet Mars 18, 2007 Rapporter Share Skrevet Mars 18, 2007 Er bildene fra Gol?Hvilket år isåfall? Se her: http://www.mb190klubb.com/bildegalleri/main.php?cmd=album Siter 89' Mercedes-Benz 190E 2.5-16 - 89' Mercedes-Benz 190D 2.5 (konebil) Mitt fotoalbum http://www.mb190klubb.com Lenke til kommentar Del på andre sider More sharing options...
theGardenSnake Skrevet Mars 12, 2008 Rapporter Share Skrevet Mars 12, 2008 en lite oppdatering her da :p fant ei russisk side der jeg kunne skrive ut alt fra A til Å om bilen min :P var litt nice den :P her er det jeg fant : model 190E 1,8 chassis 2010181F993439 approx.year 1992 367 interior: fabric "avantgarde" - red+black 569 Paint: avantgarde red metallic( rot mica ) 1992-c1994 240 outside temperature indicator (c 01,03,1982) 280 steering wheel (400mm dia.) and gearsshift lever in leather trim; on w202 390mm dia. (c.01,05,1984) 331 cassette compartment in center console (c.01,10,1989) center console below instrument panel with cassette compartment 412 electric sliding roof with tilting device (c.01,07,1983) 420 automatic transmission, floor shift (c.01,01,1963) 430 headrests in the rear (c.01,01,1977) 451 revolution counter (c.01,12,1972 no 31,10,1993) tachometer 466 central locking system (c.01,04,1970 no 31,10,1993) 470 anti-lock braking system (abs) (c.01,06,1978 no 31,10,1993) 508 outside rear view mirror left, heated and outside rear mirror, right, electrically abjustable and heated (I.h.d) outside rear viwv mirror, left and right, heated (c.01,01,1990 no 31,10,1993) 531 automatic antenna (c.01,01,1963) 583 electric window lifters ( front doors) (c.01,04,1970) 591 heat-insulting glass, all-around, heated rear window pane, 8singel-sheet safety glass) , Germany green heat-insulating glass all round, heated rear window, single pane safety glass - Germany (c.01,01,1972) 620 emission controll system vehicles with catalyst technique (c. 01,03,1985) 650 sports chassis with 15 hole light alloy rims (c.01,12,1988 no 28,02,1993) 750 becker radio Europa 2000vk (c.01,06,1990 no 31,03,1994) 954 rotating emergency flasher, front ( red light) jaja det var vell det meste, med unntak av det som er blitt gjort med merca etter den kom til Norge i 2002 da :p Har en slik godbil jeg å, en rosso :D Min er helt orginal da :P Har hørt rykter om at det er noe nivåregulering på bakdemperene, vet du noe om dette? Skal være om man har mye last baki, så skal man kunne justere trykket i demperene så man ikke tar nedi så lett. Lurer også på : 954 rotating emergency flasher, front ( red light), den har jeg ikke sett noe til. Har du noe av dette på din bil? Hadde matcha sirkusinteriøret(orginalinteriøret)med den snurrans varsellampa forran, haha Siter Lenke til kommentar Del på andre sider More sharing options...
mbfreak Skrevet Mars 12, 2008 Rapporter Share Skrevet Mars 12, 2008 Vist du har en tank ved siden av spylervæske tanken så har du enten ASD sperre eller nåvå. Siter Masse mb deler selges, ta kontakt. Lenke til kommentar Del på andre sider More sharing options...
theGardenSnake Skrevet Mars 14, 2008 Rapporter Share Skrevet Mars 14, 2008 ASD sperre, er det sperre på bakakselen? så når man spinner så drar den like mye på hvert hjul? Jeg vet hvertfall at jeg ikke har sperre på bakakselen. Men kan sjekke om jeg har den tanken du snakker om. Hvis jeg skulle hatt nivåregulering, hvor kan jeg isåfall betjene den? Trodde en periode det var et lite hvitt plastikkhjul i bagasjerommet, men det var bare manuell åpning/lukking av el.takluka. Siter Lenke til kommentar Del på andre sider More sharing options...
2Fat 2Fly Skrevet Mars 15, 2008 Rapporter Share Skrevet Mars 15, 2008 ASD er diffsperre ja:) nivåregulering funker vel at om du laster bilen full bak så skal den holde seg på samme høyde? Siter 1985 Mercedes S123 230TE TIC 1995 Mercedes E250D Lenke til kommentar Del på andre sider More sharing options...
