billig bilsterero! kan eventuelt bytte mot noe. kom med forslag!
jannis-
  • Svar 120
diverse spec på den ?
Interlaced Aramid Fibre Reinforced IMPP cone
Wide-roll, 3-layer fibre woven radial surround
Dual mass high power magnet
Extended and vented pole yoke
Enclosure use
Optional accessories:
- UD-G305 spoke grille
- UD-W300S custom enclosure box
Features TS-W305C
Frequency response 18 - 2.000 Hz
Sensitivity (1W/1m) 89 dB
Recommended sealed enclosure (Litres) 42.5
Lowest resonance frequency (FS) 35 Hz
Maximum Power 800 W
Nominal input power 400 W
Woofer size (cm) 30 cm
99 Bmw e46 (sommervogna:P)
99 Passat 1,9 tdi syncro (bruks)
95 Passat 1,9 tdi (bruks)
69 Volvo b59-60 (partybussn) mulig selges.
