Selges: 12" Red Sun woofer + Phoenix Gold QX4150 amp
licorice84
hei! jeg selger 1stk 12" Red Sun subwoofer (800w) i kasse + 1stk Phoenix Gold Qx4150 forsterker for 2000kr samlet. hadde dette i den gamle golf 2'en min, og det fungerte greit:)
har ikke anledning til å sende, så fordel om du bor i nærheten av jessheim...
pm eller sms på 98 63 43 54
litt specs på forsterker:
LED indicators for power-on and protection
Separate front and rear adjustable input sensitivity controls
Muting circuitry for soft turn-on and turn-off
Fully complimentary output stages
Advanced overload and thermal protection circuitry
High current bussbars for all high current, high voltage stages
PWM MosFet power supply
Gold plated high current power and speakers terminals
Gold plated signal input
RCA jacks Unique chrome powder coated finish
Die-cast gold plated logo badges Isolated mounting feet QLINKable
Frequency Response +/-1dB, 20Hz to 20 kHZ
Signal to Noise Ratio (A-weighted) >100dB
Max Continuous Bridged Power @ 1% THD 150 watts x 2 into 4 ohms @ 14.4 Vdc
Max Continuous Power per Channel @ 1% THD 75 watts x 4 into 2 ohms @ 14.4 Vdc
Nominal Continuous Power per Channel @ 1 % THD 60 Watts x 4 into 4 ohms @ 14.4 Vdc
IASCA/USAC Power Rating 50 Watts x 4 into 4 ohms @ 12.5 Vdc
Minimum Load when Bridged 4 Ohms
Minimum Load per Channel 2 Ohm
Input Signal Voltage Range 0.1 volts to 2 volts
Crossover Type Cont. Variable Linkwitz Riley HP,LP
Input Impedance, Standard/Balanced 12kOhms, n/a
Crossover Slope 12 dB per octave
Crossover Frequency Range 90 or 125Hz Highpass / 30-600Hz
Lowpass Factory Crossover Setting 90Hz Highpass
Hi-level Input yes (US models only)
Bass Boost 0- to +15dB @ 45 hZ
Power Supply Voltage 10Vdc to 15.5Vdc
Recommended Fuse 40 amp
Dimensions 14.86L x 8.50W x 2.10H
quattroholic!
