Vectra, den vinrøde perle! Unggutten er i gang igjen s.22
Opel-guy
  • Svar 339
Da kommer den siste updaten før jeg henter bilen :)
handla mer neon
Driver også å bygger om dekslene på dørpanelet.
har blitt delvis ferdig med midtkonsoll.
slik ble a-stolpen, temmelig bra resultat :)
Fått forsterkerne jeg har kjøpt (Auto Bilstereo)
1 stk monoblokk
Soundmagus X3200
Mono Bass 3000 Watt Amplifier
X-3200 is CLASS-D mono bass amplifier, it can delivery up to 3000W at 2ohm load.
RMS Power at 14.4V (into 2 ohm 50Hz THD+N < 2.5%)
3000 Watt
Functions
3000Wrms Class-D amplifier.
2/1-channel mode for versatile wiring.
Double Side PCB and SMD components.
Adjustable Input level, LPF, Subsonic, bass boost function.
Advanced short circuit, overload, over heat protection.
Heavy-duty terminals.
Optional wired remote controller.
2 stk 4 kanalere.
Soundmagus C160
Class-AB Hi-Fi 4-Ch Amplifier
C160 is a hi-fi 4-ch amplifier, this amplifier is consist of series hi-fi components such as audio special SMT E-caps, high accurate resistors and capacitors, hi-fi audio opamps and hi-fi power transistors.
Functions
4X160Wrms Class-AB amplifier.
2 ohm load stable.
Adjustable Input level, LPF, HPF.
Advanced short circuit, overload, over heat and low voltage protection.
2-channel mode switch available.
Gold-plated isolation terminals.
4 Ohm @14.4V RMS Power THD+N <0. 1%
160W ¡Á 4CH
2 Ohm @14.4V RMS Power THD+N < 0.1%
190W ¡Á 4CH
4 Ohm @14.4V Bridged RMS Power
350W ¡Á 2CH
Lyktene jeg har kjøpt fra Tyskland har også kommet!
