PC til bil. Motorized 7" in Dash Monitor w/GPS
luring1
Vurderer å ta inn et parti pc`er produsert for bil. 1 DIN size.
Innebygd GPS modul( Europa kart ), antenne medfølger
Perfekt som multimedia og ikke minst for å kontrollere motorstyring ved trimming av biler med datasprut som Autronic, MegaSquirt, Halltec osv, og lamda-kontroll
Garanti
Pris ca 16000,-
Skriv mail hvis interesse
Info :
Model: PDC-CRPC06
HARDWARE / General Remarks
Processor NS Geode GX1 300MHz
SDRAM 256MB PC-100
Cache Internal 16KB CPU Built-in
Display 4MB Video RAM 4MB VRAM are shared from main memory
LCD
7-INCH In-Dash LCD Display with touch
panel
800x480 pixels, 16 : 9 Wide Screen,
3 levels backlight adjustable
DVD Decoder Hardware DVD Decoder MPEG-II Real-time decode
Touch panel Yes
Mouse Left Button,
can be switched to Right Button
External COM
PORT
1 port For GPS antenna
Power input 8 ~ 16V DC / 5A or above ACC Support
SD/MMC card
reader
Built-in Support from 8MB~1GB
Audio out Stereo, 2 Channel Output
4 pins (behind the back cover)
Video out Video Out x 1 RCA Jack for AV LCD Panel Connection
Video in Video In x1 RCA Jack for Car Reverse Image
Connection
USB port USB 1.1 port x1 In the rear panel
RS232 port RS232 X 1 In the rear panel
IDE support 20GB HDD Standard 20GB 2.5” HDD
DVD ROM 8X Read DVD-ROM Drive CD/VCD/DVD/CDR/DVD-R Supported
GPS receiver Built-in GPS external antenna is include in package
Power stablizer Automatic adjustment of voltage fluctuation
Amplifier Built-in 20W x 4 Channels
Dimension 1-DIN Size
Radio tuner FM/AM Module
Frequency Support
FM: 87.5~108.0 MHz, 100K set
AM: 531~1620 KHz, 9K set
SOFTWARE Remarks
Windows System Windows XP or 98 or 2000 Optional
BIOS License AWARD
OPTIONAL EQUIPMENTS Remarks
GSM/GPRS GPRS SIM card is required External Module Optional
CONDITIONS & DURABILITY Remarks
SHOCK 60G (non-operating mode)
VIBRATION 0.2G (operating mode)
1.3G (non-operating mode)
HUMIDITY
operating mode 25. / 90%
under non-operating mode 40. / 90%
STORAGE
TEMPERATURE
-30. ~ 80.
OPERATION
TEMPERATURE
0. ~ 60.
HIGH
TEMPERATURE
90. (non-operating) for 1 hr
SALT SPRAY PH VALUE 6.5~7.2 DURATION: 144hrs
International Product Approvals
CE Global OK
FCC Global OK
E-Mark Europe Union OK
Skaffer sånne også, men med slikt system blir jo en del innstallasjons-arbeid, men så klart noen vil jo dette også for å spare penger.
Men som sagt kan jeg skaffe "seperate" eller et system i moduler, HD ( beregnet for bil, dvs tåler viberasjoner ), in dach motorisert touch screen, eller takmontert osv.
Hvis noen er interessert, send mail : knutare@netcom.no
