Quaife ATB diffbrems til Granada.
351RS
Etter å ha spurt Quaife om de hadde diffbrems til Granada, fikk jeg dette svaret:
Dear Jan,
Thanks for your email.
I'm sorry but we do not have an ATB differential for the Ford Granada.
If you want us to make an ATB diff for this car, we will need an order for minimum 10 units.
Is this of interest?
The price would be dependent on the number of units ordered.
I cannot give an idea of price at present, but you can get an idea of our ususal retail prices by seeing our ATB diff listing on the web shop.
Our ATB differentials do not have a maximum power listing.
You will break something else in the driveline before you break our diff.
Dette sier dem om funksjonen:
De koster mellom 520-720£
Quaife ATB differential for Ford Sierra 7 1/2" rear is suitable for Ford Sierra models using the 7 1/2" rear axle. Includes Scorpio flanges with 100mm diameter. This unit is a direct replacement for the standard Ford differential, and the Quaife ATB differential will transform your car's performance.
Unlike a conventional plate-style limited slip differential, the Ford Sierra 7 1/2" rear Quaife ATB differential relies on gears rather than clutch plates for its operation. That means it is much smoother in operation.
The Ford Sierra 7 1/2" rear Quaife ATB differential never locks harshly with a set pre-load of wheel slip across the driven axle, like a conventional LSD. Rather, the Ford Sierra 7 1/2" rear Quaife ATB differential automatically biases the torque away from the spinning wheel across the axle, to a constantly varying degree, and never locks.
The Ford Sierra 7 1/2" rear Quaife ATB differential has many benefits over a standard open differential, including maximising traction and minimizing wheelspin, eliminating torque steer and snatching in front wheel drive cars compared to conventional LSD units, and a maintenance-free design which retains the standard oil lubrication.
The Ford Sierra 7 1/2" rear Quaife ATB differential is proven in circuit and drag racing, rallying and road use, and is produced from Corus steel billets, and is CAD designed and CNC machined, then inspected to ISO 9001 standards.
With over 170 applications, the Quaife ATB differential is second to none. Accept no imitations!
Quaife ATB differentials are used by Ford, General Motors and Daimler-Chrysler as original equipment.
The Quaife ATB differential for Ford Sierra 7 1/2" rear is also now subject to a lifetime warranty (subject to terms and conditions).
Oppdatert 28/2
Jan,
We would ask for 1 order of 10 units, so we only deal with one person. We do not want to deal with lots of individuals to process this order.
We would ask for a 25% deposit on confirmation of your order.
Production will take approx 12 weeks from the date of receiving your deposit.
We can arrange delivery to you with TNT, however the full order would be shipped to one address.
The diff unit would be a direct replacement for the original unit. The original crownwheel should be bolted to the ATB diff, before it is fitted.
We could supply drive flanges if required, however this would increase the cost per unit.
No it would not be a modified Sierra 7.5" ATB diff. We would have to make a completely new design.
Regards,
Scott Wheeler
Quaife Technical Sales
http://www.Quaife.co.uk
hva sier dere gutter, klarer vi å skrape sammen 10 stykker?
No subsitute for cubic inches !
Prosjekttråd :Granada 351RS
Kom igjen nå GRANDA EIERE!!!!Dette tilbudet får vi ikke igjen!!!!! Da er det tilbake til å lete etter de originale diffbremsene SOM ER UMULIG Å FÅ TAK I LENGER!!!!
Her må vi få ut fingeren.
Felger, motor, styling, stereo, Playstation, møbler osv ALT DETTE FINNES DET MER AV. Men ikke DETTE ! ! ! !
HALLO GUTTA BOYS; NÅ ER DET KANSKJE PÅ TIDE Å HIVE FRAM PENGEPUNGEN!!!
Fikk et MEGET hyggelig svar fra Sarah hos Quaife idag:
Dear Jan,
Thank you for coming back to me. Now that we have seen the Granda sample diff, we can quote for a batch order as follows:
10 off £450.00 per unit
Delivery would 12-16 weeks
If you would like to proceed with a batch order please note we would require a 25% deposit before we can commence production.
If you have any queries please let me know,
Kind regards,
Sarah Lancaster
Med en kurs på 12,1 kr pr £ blir dette 5500 kr+frakt å moms, Ferdig pris til Norge med frakt, moms, osv vil bli ca 7100 nkr.
Hva sier dere nå gutter?????
  • 8 months later...
Heite faen, værre hekje ej sett her.
7000 laksa er no kupp i deres favør. hehe
Hadde ikkje nølt hakje det vår for ej held på me et 164 prosjekt som tappa tid å penga.
Om Ditte tilbudet fortsatt står når ej får byndt å gjer ferdig Granadaen min er eg med.
Men ka tid er uvisst....
Dårlig respons på ditte Granada forume seg ej...:yak:
EDIT:
SÅg no att posten er 10000 år gammal. hehe...
Sitte å lese om da du monterte diffen din.
hei og hå
Volvo 164 e bilen
