I.C.E: In case of emergency
Viking067
lite tips :
- Legg inn kontakten slik: "ICE 1 99900000" som navn - og ikke noe telefonnummer.
Slipper å lete
På denne måten slipper man at innkommende samtaler viser nummer i stedet for navn, og ambulansepersonalet slipper å bla opp og ned i telefonlister for å finne riktig nummer.
Signaturregler: www.bilforumet.no/faq.php
  • 1 month later...
  • Svar 48
ICE in your mobile phone
The original concept, conceived by Cambridge paramedic Bob Brotchie, involved putting the acronym ICE in front of your designated emergency contact.
Follow these hints to get the best out of ICE:
Make sure the person whose name and number you are giving has agreed to be your ICE partner
Make sure your ICE partner has a list of people they should contact on your behalf - including your place of work
Make sure your ICE person's number is one that's easy to contact, for example a home number could be useless in an emergency if the person works full time
Make sure your ICE partner knows about any medical conditions that could affect your emergency treatment - for example allergies or current medication
Make sure if you are under 18, your ICE partner is a parent or guardian authorised to make decision on your behalf - for example if you need a life or death operation
Should your preferred contact be deaf, then type ICETEXT then the name of your contact before saving the number
My phone doesn't show the callers name any more
This will be because your ICE contact number is a duplicate entry of another contact in your phone book.
If you have two numbers the same, your phone won't know which one to display so it will show just the number. To get round this, simply type a * after the number under your ICE contact. It will still work and will cure the caller-ID problem.
Greit den siste der.. Med å bruke stjerne * på slutten av numret. Feks. +47 95959595* Veldig bra tema som jeg ikke hadde hørt om ,før på forumet.
  • 3 years later...
ICE er nok de fleste i ambulansetjenesten, politi og brannvesenet klar over hva betyr og desto flere som bruker det så blir det en nok en standard etterhvert.
Jeg kræsja sykkelen og måtte sette inn tannimplantat. Kom til å tenke på sikkerhet og ikke minst donor situasjon. Mange har Smartphone i dag og dere kan laste ned donorkort for mobilen her. Kjør forsiktig, ordne donorkort og gi blod regelmessig :)
