norwegian forza drifters (Søndag 23. september kl 18.00)
  • Svar 590
<a href="http://photobucket.com" target="_blank"><img src="http://i26.photobucket.com/albums/c126/Wheelsman/drfter.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Forza motorsport 2 geek
Gamertag: Wheelsman
Fav bil: Nissan silvia s15
Det hjelper dårlig med en tiger på tanken når en har en sau bak rattet..
Hvis noen sliter med dette problemet når du prøver ¨joine:
"Failed to connect the game"
så les her:
This is a NAT or hardware compatiability issue. First please make sure your Cable/DSL modem and router are on the Xbox Live approved hardware list. This is located here:
http://www.xbox.com/en-US/support/co.../equipment.htm
When you attempt to join a session your Xbox will attempt to connect to every other person already in the lobby. If anyone in that lobby is unable to transfer data back and forth with you, you will not be able to enter the lobby.
On the system tab of your dashboard run the networking test. The last test determines what kind of Network Address Translation (NAT) is being used in your network. If your NAT is 'Strict', you should try to lower your security settings for your router/firewall until the NAT is set to Moderate.
For best chance to join all mplay sessions you should have an 'Open' NAT.
Invariably one of you will point out that you can join sessions when playing other games. Other games are not Forza Motorsport2. Racers are not FPSs. In addition to matchmaking we support the overhead of a massive array of leaderboard data as well as auction house, XeTV, downloadable ghosts, uploadable photos, etc. Our network code is different than 'their' network code for these, and other, reasons.
Prøv igjen med OPEN NAT!
- 85 Toyota Levin AE86 - F20C
- 87 Toyota Supra MK3 - 1JZ-GTE
Bilder i fra en rimelig rå episode i går. Skjønner ikke hvordan det er mulig at det ikke ble noe sammestøt her.
- BMW E30 320iS '90 bane- og kosebil / BMW E39 520i '98 bruksbil
x BMW E28 518i '85
x BMW E30 325i '89 x BMW E34 Alpina B10 '91
x BMW E30 320i '88 x BMW E34 520i '90
rakanishu - drifting away
Da fikk jeg prøvd forza2, Rå fysikk da. tøff grafikk. Og ganske ålreit å drifte i. Men.... Det er ikke noe clutch, og den brukes så mye i drifting at det blir for dumt uten. Synd de ikke tok den med :(.
Sant det, men ta en titt på kontrolleren, hvor mange knapper har man til rådighet? Og hvem funksjon skulle man byttet ut med clutchen? Brekket?
Tror nok ikke vi får brekk i noe Xbox360 ratt før vi får en egen "G25" variant :)
Kunne ikke komme å drifte på Søndag , hadde guttungen min da.. har gjort klar denne bilen her.
Tid er neste gathering for Norwegian Drifters ? Skal sette skrift på bilen når jeg kommer hjem i dag. :D
Onsdag kl 19.00 :)
