Dekktrykk?
xGrape
Fyll 2.2(framme)-2.4(bak) bar hvis du har over 50 profil. Fyll 2.4 bar på alle dekkene hvis du har under 50 profil, og mer bak hvis du pleier å ha passasjerer bak.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
