Hva er en halllgiver
Håkon A
Brukes bla. i fordeleren:
http://autorepair.about.com/library/glossary/bldef-291.htm
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/hall.html
"The classical Hall effect
The Hall effect was discovered by Edwin Hall in 1879.
It is well known that a charged particle moving in a magnetic field feels a `Lorentz' force perpendicular to its direction of motion and the magnetic field. As a direct consequence of this Lorentz force, charged particles will accumulate to one side of a wire if you send current through it and hold it still in a (perpendicular) magnetic field. This is called the Hall effect. The voltage drop at right angles to the current is called the Hall voltage; The current divided by the Hall voltage is called the Hall conductance."
Produktark fra Honeywell
