Drifteoppsett tips
Blix1
Dekk:
2 bar/2.5bar
Camber:
Rundt 1-1,5/mellom 1.5-3.5( bruker stock selv)
Toe:
+0.1/-0.1
Stabstag:
stivere bak enn fremme
Springs:
Diff:
70%-100%.
du må prøve deg frem, det er eneste måten å lære på. er ikke noen mester selv, men prøver å hjelpe så godt jeg kan.
Hær er det noen setups: http://www.forzacentral.com/forum/sh...ad.php?t=22022
1994 VW Passat 1,8
1991 Seat Ibiza 1,5 SXI (Spikker)
1995 Opel Vectra 2,0 16v (Spikker)
1977 Opel Ascona 1,9 2D (Kræsjet og solgt)
Xbox Live GT: xPellaRx
Drift Specc: 1997 Bmw m3 E36
1997 BMW M3 E36 by Ale
Car Manufacturer and Name: BMW M3 E36
Class: B PI: 699
Power:
Full sport kit. Naturally aspirated wonderbox.
Platform and Handling:
Full race kit, 1.5 way diff, sport weight reduction.
Wheels:
18", stock width, stock compound
Aero:
BMW Motorsport Front and rear bumpers, stock wing.
[Car Settings]
Tire Pressure
Front:33 psi
Rear: 38 psi
Gearing
Final Drive 3.48
Alignment
Camber front: -1.5
Camber Rear: -0.6
Toe Front: +0.1
Toe Rear: +0.1
Front Caster: 4.3 degrees
Anti Roll Bars
Front: 10.94
Rear: 13.94
Springs
Front: 518 lb/in
Rear: Between 550 and 575 seems a sweet spot.
Ride Height
Front: Lowest
Rear: 5.9 in
Rebound Damping
Front: 6.8
Rear: 7.0
Bump Stiffness
Front: 3.5
Rear: 4.0
DownForce
Front: 90lb
Rear: Stock
Braking Force
Balance: 40% front
Pressure: 140%
Differential
Rear Accel: 65%
Rear Decel: N/A
Note: Car is wonderful holding the drifts (using a M$ wheel, as per usual) but a little sketchy powering over as the engine just loves to rev. Throttle control and immediate countersteer are a must.
Sitat:
Car Manufacturer and Name: 2005 BMW Motorsport M3 E46 Coupe
Class: A - 845
List of Upgrades:
ENGINE & POWER
All "Sport" engine modifications
PLATFORM & HANDLING
All "Race" modifications w/ 1.5 lsd
TIRES & RIMS
-Sport tire compound
-Stock tire width
-Stock rim size
-Custom rims
BODY & AERO
(optional)
Car Settings:
Tire Pressure
Front: 27
Rear: 28
Gearing:
Final Drive: 3.19
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -2.0
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.3
Anti Roll Bars
Front: 18.20
Rear: 18.50
Springs
Front: 452.3
Rear: 454.7
Ride Height
Front: 6.8
Rear: 6.8
Rebound Damping
Front: 7.2
Rear: 7.1
Bump Stiffness
Front: 3.4
Rear: 3.8
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 138%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 63%
Rear Decel: N/A
Info:
Fun, base setup that works great as is. As always, fine-tune to your specific needs and drift style.
Sitat:
Car Manufacturer and Name: 1969 Chevrolet Camaro SS Coupe
Class: A - 756
List of Upgrades:
ENGINE & POWER
All "Sport" engine modifications w/ Street Positive Displacement Supercharger only
PLATFORM & HANDLING
TIRES & RIMS
-'Y-rated' street tire compound
-Stock tire width
-Stock rim size
-Custom rims
BODY & AERO
(optional)
Car Settings:
Tire Pressure
Front: 27
Rear: 29
Gearing:
Final Drive: 3.05
1st: 2.89
2nd: 1.83
3rd: 1.22
4th: 0.99
5th: 0.85
6th: 0.73
Alignment
Camber front: -1.9
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.1
Anti-Roll Bars
Front: 19.19
Rear: 20.08
Springs
Front: 469.0
Rear: 481.1
Ride Height
Front: 5.6
Rear: 5.6
Rebound Damping
Front: 5.6
Rear: 5.9
Bump Stiffness
Front: 3.1
Rear: 3.3
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 132%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 59%
Rear Decel: N/A
Info:
This classic muscle car was almost born to drift. Initiates really easy so start mastering your throttle control to really see what this car is capable of.
Sitat:
Car Manufacturer and Name: 2006 Dodge Charger SRT8
Class: S - 895
List of Upgrades:
ENGINE & POWER
All "Race" engine modifications
PLATFORM & HANDLING
TIRES & RIMS
"Y-rated" street tire compound/Max tire width/Stock rim size/Custom rims
BODY & AERO
N/A
Car Settings:
Tire Pressure
Front: 28
Rear: 30
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.84
3rd: 1.42
4th: 1.12
5th: 1.00
6th: 0.85
Alignment:
Camber front: -2.1
Camber Rear: -0.7
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.0
Anti Roll Bars:
Front: 10.22
Rear: 11.91
Springs:
Front: 543.2
Rear: 503.5
Ride Height:
Front: 5.1
Rear: 5.1
Rebound Damping:
Front: 7.1
Rear: 6.1
Bump Stiffness:
Front: 3.6
Rear: 3.0
DownForce:
Front: N/A
Rear: N/A
Braking Force:
Balance: 50%
Pressure: 100%
Differential:
Front Accel: N/A
Front Decel: N/A
Rear Accel: 77%
Rear Decel: 75%
Info:
Intended for intermediate to advance drifters, this car I use regularly on Sukuba East track. Lots of power, which requires a steady gas finger for you to drift this beast properly. If your new to drifting, I wouldn't recommend trying this out yet.
Sitat:
Car Manufacturer and Name 2004 Ferrari F430
Class S - 953
List of Upgrades
ENGINE & POWER
Sport Intake & Exhaust only
PLATFORM & HANDLING
All Race modifications w 1.5 lsd
TIRES & RIMS
-Stock tire width
-Stock rim size
-Custom rims
BODY & AERO
(optional)
Car Settings
Tire Pressure
Front 26
Rear 27
Gearing
Final Drive 3.57
1st 3.23
2nd 1.78
3rd 1.26
4th 1.07
5th 0.93
6th 0.82
Alignment
Camber front -1.7
Camber Rear -0.5
Toe Front 0.2
Toe Rear 0.1
Front Caster 5.1
Anti-Roll Bars
Front 19.07
Rear 20.09
Springs
Front 458.2
Rear 475.9
Ride Height
Front 3.3
Rear 3.3
Rebound Damping
Front 6.9
Rear 7.4
Bump Stiffness
Front 3.7
Rear 4.2
DownForce
Front NA
Rear NA
Braking Force
Balance 50%
Pressure 132%
Differential
Front Accel NA
Front Decel NA
Rear Accel 63%
Rear Decel NA
Info
Not much is needed in the power department for this exotic beauty. Drifts well in 2nd gear, though I recommend tuning the gear ratios depending on the track your drifting on. Recommended for intermediate to advanced users.
Sitat:
Car Manufacturer and Name: 2005 Honda NSX-R
Class: S - 946
List of Upgrades:
ENGINE & POWER
-All "Sport" engine modifications w/ Sport Positive Displacement Supercharger only
PLATFORM & HANDLING
All "Race" modifications w/ 1.5 Limited Slip Differential
TIRES & RIMS
BODY & AERO
Optional
Car Settings:
Tire Pressure:
Front: 28
Rear: 30
Gearing:
Final Drive: 3.30
1st: 3.80
2nd: 2.18
3rd: 1.62
4th: 1.19
5th: 1.00
6th: 0.85
Alignment:
Camber front: -1.7
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.5
Anti Roll Bars:
Front: 18.57
Rear: 19.41
Springs:
Front: 389.6
Rear: 418.9
Ride Height:
Front: 4.1
Rear: 4.0
Rebound Damping:
Front: 6.5
Rear: 7.8
Bump Stiffness:
Front: 3.4
Rear: 4.2
DownForce:
Front: N/A
Rear: N/A
Braking Force:
Balance: 50%
Pressure: 112%
Differential:
Front Accel: N/A
Front Decel: N/A
Rear Accel: 58%
Rear Decel: N/A
Info:
This car drifts well in 2nd for those short corners and 3rd for the wider ones. Use this as a base and tune camber, tire pressure, spring rate to work with your own drift style.
Sitat:
Car Manufacturer and Name: 2003 Honda S2000
Class: A - 840
List of Upgrades:
ENGINE & POWER
All "Sport" engine modifications w/ positive displacement supercharger only
PLATFORM & HANDLING
TIRES & RIMS
-"Y-rated" street tire compound
-[Front 225/40R18 Rear 245/35R18] tire width
-Stock rim size
-Custom rims
BODY & AERO
(optional)
Car Settings:
Tire Pressure
Front: 27
Rear: 29
Gearing:
Final Drive: 3.18
1st: 3.03
2nd: 1.98
3rd: 1.47
4th: 1.15
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.7
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.1
Anti Roll Bars
Front: 17.97
Rear: 18.47
Springs
Front: 383.9
Rear: 413.1
Ride Height
Front: 5.0
Rear: 5.1
Rebound Damping
Front: 6.5
Rear: 6.5
Bump Stiffness
Front: 3.3
Rear: 3.3
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 134%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 59%
Rear Decel: N/A
Info:
Suprisingly fun drift car that keeps on sliding with manageable control. Good base setup to fine tune to your specific style!
Sitat:
Car Manufacturer and Name: 1961 Jaguar E-Type S1
Class: A - 791
List of Upgrades:
ENGINE & POWER
PLATFORM & HANDLING
TIRES & RIMS
BODY & AERO
Optional
Car Settings:
Tire Pressure
Front: 29
Rear: 30
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.9
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.6
Anti Roll Bars
Front: 18.96
Rear: 20.04
Springs
Front: 358.9
Rear: 377.8
Ride Height
Front: 6.9
Rear: 6.9
Rebound Damping
Front: 6.8
Rear: 7.2
Bump Stiffness
Front: 3.3
Rear: 3.6
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 113%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 64%
Rear Decel: N/A
Info:
Don't be fooled by this classic, its actually quite fun! Solid drift setup for anyone to fine-tune to their personal style.
Sitat:
Car Manufacturer and Name: 2001 Mazda Mazdaspeed Roadster
Class: A - 754
List of Upgrades:
ENGINE & POWER
All "Sport" engine modifications w/ Apexi Sport Turbo
PLATFORM & HANDLING
TIRES & RIMS
-Stock tire width
-Stock rim size
-Custom rims
BODY & AERO
(optional)
Car Settings:
Tire Pressure
Front: 28
Rear: 29
Gearing:
Final Drive: 3.00
1st: 2.83
2nd: 1.80
3rd: 1.36
4th: 1.16
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.8
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.2
Anti Roll Bars
Front: 19.08
Rear: 19.77
Springs
Front: 324.8
Rear: 331.6
Ride Height
Front: 4.7
Rear: 4.7
Rebound Damping
Front: 6.6
Rear: 7.0
Bump Stiffness
Front: 3.3
Rear: 3.5
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 132%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 61%
Rear Decel: N/A
Info:
Great base setup to fine-tune with. Drifts great in 2nd gear most of the time, and controls quite nicely.
Sitat:
Car Manufacturer and Name: 1990 Mazda Savanna RX-7
Class: A - 752
List of Upgrades:
ENGINE & POWER
PLATFORM & HANDLING
TIRES & RIMS
"Y-Rated" street tire compound/Stock tire width/Stock rim size/Stock rims
BODY & AERO
Stock
Car Settings:
Tire Pressure
Front: 29
Rear: 31
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -2.1
Camber Rear: -1.1
Toe Front: -0.2
Toe Rear: 0.0
Front Caster: 4.9
Anti Roll Bars
Front: 16.88
Rear: 17.78
Springs
Front: 353.2
Rear: 378.3
Ride Height
Front: 4.4
Rear: 4.4
Rebound Damping
Front: 6.3
Rear: 6.3
Bump Stiffness
Front: 3.1
Rear: 3.4
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 105%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 63%
Rear Decel: N/A
Info:
Running Sport modifications so you guys can practice drifting a low end setup. Upgrade to race parts as needed once you feel comfortable with the car and fine tune to your style.. aka tire pressure, camber, etc.
Sitat:
Car Manufacturer and Name: 1995 Mazda INGS RX-7
Class: S - 888
List of Upgrades:
ENGINE & POWER
PLATFORM & HANDLING
All "Race" modifications w/ 1.5 limited slip differential
TIRES & RIMS
Stock tire compound/Max tire width/Stock rim size/Custom rims
BODY & AERO
N/A
Car Settings:
Tire Pressure
Front: 27
Rear: 29
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.7
Camber Rear: -0.6
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.0
Anti Roll Bars
Front: 12.37
Rear: 14.70
Springs
Front: 377.2
Rear: 346.5
Ride Height
Front: 3.7
Rear: 3.7
Rebound Damping
Front: 67.4
Rear: 6.1
Bump Stiffness
Front: 3.7
Rear: 3.0
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 108%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 58%
Rear Decel: N/A
Info:
Here's a base drift setup for you guys to work off of. Gearing was left stock, just some tweaks to other areas to get your car sideways. To get you started, start tuning the tire pressure, camber, and gear ratios as needed. Stiffen the back springs if needed and tweak the sway bars.
Sitat:
Car Manufacturer and Name: 1997 Mazda RX-7 Gen 3
Class: S - 868
List of Upgrades:
ENGINE & POWER
PLATFORM & HANDLING
TIRES & RIMS
Tire Width: 235/30R19
Stock rim size
Custom rims
BODY & AERO
Optional
Car Settings:
Tire Pressure
Front: 28
Rear: 30
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.8
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.6
Anti Roll Bars
Front: 16.67
Rear: 17.27
Springs
Front: 371.5
Rear: 387.0
Ride Height
Front: 5.7
Rear: 5.7
Rebound Damping
Front: 6.6
Rear: 6.6
Bump Stiffness
Front: 3.3
Rear: 3.3
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 112%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 58%
Rear Decel: N/A
Info:
Good base drift configuration with stock gear ratios. Test drive for a while and tune as necessary to your preferred style.
Sitat:
Car Manufacturer and Name: 2004 Mazda RX-8 Mazdaspeed
Class: S - 863
List of Upgrades:
ENGINE & POWER
-Stock rwd engine
PLATFORM & HANDLING
TIRES & RIMS
BODY & AERO
Optional
Car Settings:
Tire Pressure
Front: 27
Rear: 29
Gearing:
Final Drive: 4.21
1st: 3.10
2nd: 1.75
3rd: 1.24
4th: 1.05
5th: 0.91
6th: 0.76
Alignment
Camber front: -2.3
Camber Rear: -0.8
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.4
Anti Roll Bars
Front: 16.79
Rear: 17.79
Springs
Front: 413.4
Rear: 421.7
Ride Height
Front: 5.2
Rear: 5.2
Rebound Damping
Front: 6.5
Rear: 6.5
Bump Stiffness
Front: 3.2
Rear: 3.3
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 110%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 64%
Rear Decel: N/A
Info:
Nice drift setup to work off of. This car is all about throttle control. so watch your response and countersteer. Again, these are my personal setups which work great for me. Fine tune to your personal style. If you use any of my setups posted here, run all assists off with manual transmission.
Sitat:
Car Manufacturer and Name: 1994 Nissan Twin Turbo 300ZX
Class: A - 841
List of Upgrades:
ENGINE & POWER
PLATFORM & HANDLING
TIRES & RIMS
"Y-rated" street tire compound/Stock tire width/Stock rim size/Stock rims
BODY & AERO
Stock
Car Settings:
Tire Pressure
Front: 27
Rear: 29
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 2.00
3rd: 1.46
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.9
Camber Rear: -1.1
Toe Front: -0.2
Toe Rear: 0.0
Front Caster: 5.2
Anti Roll Bars
Front: 12.87
Rear: 13.75
Springs
Front: 446.5
Rear: 421.2
Ride Height
Front: 4.2
Rear: 4.2
Rebound Damping
Front: 7.1
Rear: 6.0
Bump Stiffness
Front: 3.3
Rear: 3.1
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 109%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 68%
Rear Decel: N/A
Info:
Base drift setup with sport modifications. Tuned with control in mind, so drifting should be picked up rather easy for those just learning. As always, fine tune based on your preferred style.
Sitat:
Car Manufacturer and Name: Nissan Custom Fairlady 350Z (Pre-Order)
Class: S - 980
List of Upgrades:
ENGINE & POWER
All "Street" engine modifications w/ HKS Sport Centrifugal Supercharger
PLATFORM & HANDLING
TIRES & RIMS
Sport Compound tires/Stock rim size/custom rims
BODY & AERO
N/A
Car Settings:
Tire Pressure
Front: 28
Rear: 30
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -2.4
Camber Rear: -0.7
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 4.9
Anti Roll Bars
Front: 13.89
Rear: 16.04
Springs
Front: 482.6
Rear: 460.0
Ride Height
Front: 3.5
Rear: 3.2
Rebound Damping
Front: 8.9
Rear: 8.2
Bump Stiffness
Front: 4.4
Rear: 4.1
DownForce
Front: 188
Rear: 319
Braking Force
Balance: 50%
Pressure: 126%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 62%
Rear Decel: N/A
Info:
Almost a similiar setup as the regular Z, this one also drifts well in 3rd. I set this one up to control a bit more easily as you initiate the drift. Just don't come into the turns too fast, this car will drift at fairly low speeds.
Sitat:
Car Manufacturer and Name: Nissan Fairlady 350Z
Class: S - 855
List of Upgrades:
ENGINE & POWER
All "Street" engine modifications w/ HKS Sport Turbo
PLATFORM & HANDLING
TIRES & RIMS
"Y-rated" Street Compound tires/max tire width/Stock rim size/custom rims
BODY & AERO
Stillen Full Body Kit (Optional)
Car Settings:
Tire Pressure
Front: 28
Rear: 30
Gearing:
Final Drive: 3.30
1st: 3.74
2nd: 1.93
3rd: 1.40
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.2
Camber Rear: -0.4
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 4.7
Anti Roll Bars
Front: 15.77
Rear: 17.00
Springs
Front: 441.0
Rear: 515.6
Ride Height
Front: 3.2
Rear: 2.9
Rebound Damping
Front: 6.8
Rear: 6.3
Bump Stiffness
Front: 4.6
Rear: 5.3
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 115%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 70%
Rear Decel: 50%
Info:
Here's a setup I use regularly on my 350z. Just tap the e-brake till it starts to slide, then use your throttle as a way to control your angle and speed. As you get used to it, start tweaking with the tire pressure in the back if you want it to be more loose. Increase the front camber to give the front tires more control during a drift or vice versa. Just have to find your preferred style and fine tune.
Sitat:
Car Manufacturer and Name: 1969 Nissan Fairlady Z 432R
Class: A - 813
List of Upgrades:
ENGINE & POWER
All "Sport" engine modifications w/ SR20DET swap
PLATFORM & HANDLING
TIRES & RIMS
"Y-rated" street tire compound/Stock tire width/Stock rim size/Custom rims
BODY & AERO
Forza 2 wing
Car Settings:
Tire Pressure
Front: 28
Rear: 31
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.5
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.0
Anti Roll Bars
Front: 15.13
Rear: 16.73
Springs
Front: 294.4
Rear: 306.7
Ride Height
Front: 5.6
Rear: 5.6
Rebound Damping
Front: 6.6
Rear: 7.2
Bump Stiffness
Front: 3.3
Rear: 3.3
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 110%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 56%
Rear Decel: N/A
Info:
Fun drift setup with this classic nissan car. Fine tune as needed to fit your style.
Sitat:
Car Manufacturer and Name: Nissan Silvia s14
Class: S PI: 853
List of Upgrades:
Engine:
Full race kit, max everything.
Full race kit, max everything. Max weight removed.
Tires and rims:
Y-rated street compound.
Aero:
Using full C-West body kit (Optional)
Car Settings:
Tire Pressure
Front: 26
Rear: 28
Gearing:
Final Drive, 4.17
First, 3.12
Second, 1.58
Third, 1.09
Fourth, 0.90
Fifth, 0.78
Sixth, 0.69
Alignment
Camber front: -2.1
Camber Rear: -1.5
Toe Front: -0.2
Toe Rear: -0.1
Front Caster: 5.1
Anti Roll Bars
Front: 19.81
Rear: 20.80
Springs
Front: 396.3
Rear 405.1
Ride Height
Front: 5.3
Rear: 5.3
Rebound Damping
Front: 6.4
Rear: 6.7
Bump Stiffness
Front: 5.3
Rear: 5.6
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: Neutral
Pressure: 145%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 69%
Rear Decel: 56%
Info:
Spent a good deal testing and tuning to fit my style. It will drift when you want it too and still maintains decent control. Just be sensitive on the throttle or you'll be spinning out in frustration. I'd advise tweaking it after you set your car up with this to conform to your own drifting tastes.
Sitat:
Drift Specc:
S13
Nissan Silvia S13
355 hp / 294 ft-lbs
Sport Intake
Sport Exhaust
Sport Ignition
Sport Fuel System
Race Cams & Valves
Sport Engine Block
Stock I/C & Turbo
Stock Brakes
Race Springs & Dampers
Race Anti Roll Bars
Stock Transmission
Sport Clutch
Sport Flywheel
Race Driveline
Race Differential
Sport Weight Reduction
Stock Tires
Tire Width 225/235
16" Wheels
Settings (F/R)
Tire Pressure - 35/40
Camber - -2.0/-1.0
Toe - +0.2/0.0
Caster - 6.0
Anti Roll Bars - 9.56/10.78
Springs - 419.5/388.8
Height - 4.6/4.6
Rebound - 6.8/6.1
Bound - 3.4/3.0
Differential 90/60
ing tire
Sitat:
Car Manufacturer and Name: 2003 Nissan Skyline Coupe 350GT
Class: S - 865
List of Upgrades:
ENGINE & POWER
-Stock rwd engine
PLATFORM & HANDLING
TIRES & RIMS
BODY & AERO
Nismo body kit (optional)
Car Settings:
Tire Pressure
Front: 28
Rear: 30
Gearing:
Final Drive: 3.80
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.9
Camber Rear: -0.5
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.3
Anti Roll Bars
Front: 13.82
Rear: 14.23
Springs
Front: 445.6
Rear: 451.4
Ride Height
Front: 4.7
Rear: 4.4
Rebound Damping
Front: 6.6
Rear: 6.2
Bump Stiffness
Front: 3.4
Rear: 3.5
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 112%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 62%
Rear Decel: N/A
Info:
Base drift setup with stock gear ratios. Easy to learn with and tune to your own personal style. As always, my setups are drifted with all assists off and manual transmission.
Sitat:
Car Manufacturer and Name: 2006 Proto Motors Proto Spirra
Class: S - 876
List of Upgrades:
ENGINE & POWER
All "Street" engine modifications w/ Street Positive Displacement Supercharger only
PLATFORM & HANDLING
TIRES & RIMS
-Stock tire width
-Stock rim size
-Custom rims
BODY & AERO
(optional)
Car Settings:
Tire Pressure
Front: 27
Rear: 29
Gearing:
Final Drive: 2.80
1st: 2.89
2nd: 1.84
3rd: 1.36
4th: 1.17
5th: 1.00
6th: 0.85
Alignment
Camber front: -2.0
Camber Rear: -0.6
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.2
Anti-Roll Bars
Front: 17.81
Rear: 18.69
Springs
Front: 340.5
Rear: 348.8
Ride Height
Front: 3.6
Rear: 3.6
Rebound Damping
Front: 6.3
Rear: 7.6
Bump Stiffness
Front: 2.9
Rear: 3.8
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 121%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 62%
Rear Decel: N/A
Info:
Decent setup to work off of. Meant for the intermediate drifter in mind.
Sitat:
Car Manufacturer and Name: 1968 Shelby GT-500KR
Class: A - 756
List of Upgrades:
ENGINE & POWER
PLATFORM & HANDLING
TIRES & RIMS
-[Front: 235/65R15 Rear: 235/65R15] tire width
-Stock rim size
-Custom rims
BODY & AERO
(optional)
Car Settings:
Tire Pressure
Front: 25
Rear: 27
Gearing:
Final Drive: 3.29
1st: 2.89
2nd: 1.73
3rd: 1.22
4th: 0.98
5th: 0.85
6th: 0.76
Alignment
Camber front: -1.7
Camber Rear: -0.5
Toe Front: 0.3
Toe Rear: 0.0
Front Caster: 5.1
Anti-Roll Bars
Front: 16.04
Rear: 16.71
Springs
Front: 436.6
Rear: 445.3
Ride Height
Front: 7.2
Rear: 7.2
Rebound Damping
Front: 6.1
Rear: 5.6
Bump Stiffness
Front: 3.5
Rear: 3.0
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 138%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 65%
Rear Decel: N/A
Info:
This turned out to be a somewhat complex tuning session. Loves to get sideways yet requires good handling skills. Beginner drifters might want to steer clear of this till you've mastered the basics of proper drifting and control.
Sitat:
Car Manufacturer and Name: 1992 Toyota Supra 2.0 GT Twin Turbo
Class: S - 855
List of Upgrades:
ENGINE & POWER
-2JZ-GTE Swap
-All "Street" engine modifications w/ Sport intercooler and Sport Turbo
PLATFORM & HANDLING
TIRES & RIMS
BODY & AERO
Kaminari Body Kit (Optional)
Car Settings:
Tire Pressure
Front: 28
Rear: 30
Gearing:
Final Drive: 3.30
1st: 3.33
2nd: 2.10
3rd: 1.42
4th: 1.18
5th: 1.00
6th: 0.85
Alignment
Camber front: -2.1
Camber Rear: -0.6
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.3
Anti Roll Bars
Front: 16.25
Rear: 17.70
Springs
Front: 433.8
Rear: 452.9
Ride Height
Front: 4.5
Rear: 4.5
Rebound Damping
Front: 6.7
Rear: 7.0
Bump Stiffness
Front: 3.3
Rear: 4.3
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 112%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 62%
Rear Decel: N/A
Info:
Really enjoyed tuning this car, very suprised by its handling and overall drifting ability. This should be a fun car to work off of to your own personal tastes.
Sitat:
Alright for this setup, I have these parts in my car, Intake, Exhaust, Ignition, Cams, Sport Tires, Biggest Tire width, and biggest tire size. All of the parts are the best ones possible in that categorize.
Here is the setup (from top to bottom)
Tires
47
35
Alignment
-3.0
-0.5
1.7
-0.5
6.5
Anti-roll bars
38
18
Springs
350
274
5.5
5.4
Dampening
11.5
7.5
10.5
7.5
Brakes
40%
140%
Differential
55%
65%
Those are the only things you need to change, if its not listed, dont change it!
Hope this setup works for you as well at it has worked for me!
Sitat:
Car Manufacturer and Name: 1985 Toyota Sprinter Trueno
Class: S - 866
List of Upgrades:
ENGINE & POWER
All "Race" engine modifications w/ positive displacement supercharger only
PLATFORM & HANDLING
TIRES & RIMS
"Race" tire compound/Stock tire width/Stock rim size/Stock rims
BODY & AERO
Stock
Car Settings:
Tire Pressure
Front: 27
Rear: 29
Gearing:
Final Drive: 3.30
1st: 2.89
2nd: 1.82
3rd: 1.40
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -0.6
Camber Rear: -0.2
Toe Front: -0.2
Toe Rear: 0.0
Front Caster: 5.0
Anti Roll Bars
Front: 12.67
Rear: 13.32
Springs
Front: 281.7
Rear: 285.6
Ride Height
Front: 5.4
Rear: 5.4
Rebound Damping
Front: 6.8
Rear: 6.6
Bump Stiffness
Front: 3.3
Rear: 3.1
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 112%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 36%
Rear Decel: 33%
Info:
This setup will drift really well in 3rd gear for almost all corners. The car wants to get sideways so make sure you countersteer quickly yet softly once the back tires start spinning. As always, tune this setup to your liking once you get enough time out on the track.
Sitat:
Car Manufacturer and Name: 2005 Vauxhall Monaro VXR
Class: S - 857
List of Upgrades:
ENGINE & POWER
-All "Sport" engine modifications w/ Street Positive Displacement Supercharger only
-Stock rwd engine
PLATFORM & HANDLING
TIRES & RIMS
BODY & AERO
(optional)
Car Settings:
Tire Pressure
Front: 24
Rear: 26
Gearing:
Final Drive: 3.80
1st: 2.89
2nd: 1.99
3rd: 1.51
4th: 1.20
5th: 1.00
6th: 0.85
Alignment
Camber front: -2.2
Camber Rear: -0.7
Toe Front: 0.0
Toe Rear: 0.0
Front Caster: 5.0
Anti Roll Bars
Front: 16.90
Rear: 17.13
Springs
Front: 447.0
Rear: 457.5
Ride Height
Front: 5.6
Rear: 5.6
Rebound Damping
Front: 7.3
Rear: 6.4
Bump Stiffness
Front: 3.6
Rear: 3.0
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 113%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 64%
Rear Decel: N/A
Info:
This car was actually alot of fun to tune. This Monaro loves to get sideways, so basic drifting skills are essential. I left the gear ratios stock, so tune them as necessary to fit your preferred style along with everything else.
Sitat:
Car Manufacturer and Name: Vauxhall Astra w/ rwd swap
Class: A - 713
List of Upgrades:
ENGINE & POWER
All "Street" engine modifications w/ turbo
PLATFORM & HANDLING
All "Race" modifications with 1.5 lsd
TIRES & RIMS
"Y-rated Street" tire compound/Stock tire width/Stock rim size/Stock rims
BODY & AERO
Stock
Car Settings:
Tire Pressure
Front: 28
Rear: 30
Gearing:
Final Drive: 3.30
1st: 3.15
2nd: 1.75
3rd: 1.31
4th: 1.15
5th: 1.00
6th: 0.85
Alignment
Camber front: -1.2
Camber Rear: -0.6
Toe Front: -0.2
Toe Rear: 0.0
Front Caster: 5.0
Anti Roll Bars
Front: 12.50
Rear: 14.02
Springs
Front: 431.2
Rear: 471.9
Ride Height
Front: 4.9
Rear: 4.9
Rebound Damping
Front: 6.9
Rear: 7.3
Bump Stiffness
Front: 3.5
Rear: 3.5
DownForce
Front: N/A
Rear: N/A
Braking Force
Balance: 50%
Pressure: 108%
Differential
Front Accel: N/A
Front Decel: N/A
Rear Accel: 42%
Rear Decel: N/A
Info:
Setup mostly for those just getting started. Car will get sideways but still give you alot of control as you learn how to drift. Once you get the hang of it, start tweaking the spring stiffness, tire pressure, and camber to get the car sliding more easily as you become more comfortable.
<-'VåtSokk'->
