Skal kjøpe mej corrado
Bolln
Do you know how to test your boost levels?
1. Start Motor
2. Move the MFA selector to "2"
3. Press and hold the MFA end button (keep holding)
4. Stop motor
5. Start Motor
6. Release the MFA end button.
7. Press the MFA End button one time.
You should now see 84-104 readings fluctuating with idle. Anything higher than 104 is not right (vacuum leak). Much less than 84 is probably too much timing advance.
__________________
2001 golf iv tdi 4motion highline- til salgs
1987 golf 1 cab
1991 corrado g60
1979 volvo 242 gruppe A
