chief: vr6 kompressor prosjekt Oppdatert 31/1-08
monsterchief
  • Svar 82
her er litt facts om kitet for de som har lyst å vite hva jeg putter inn under panseret:
Stage 1
• GIAC custom tuned stage 1 software
• All stages fully OBD1 & OBD 2 compliant
• RPM limiter increased to 7000 rpm
• Soft rev limiters completely removed
• Increased SC pulley belt wrap
• Bosch OEM pressure relief bypass systems
• Polyproylene custom molded plastic pipework
• 6061 Billet aluminum CNC bracketry
• 4 ply silicon couplers with OEM screw clamps
• AN swivel fittings with high pressure OEM oil lines
• Proprietary Gates OEM serpentine belt
• Optional 2 year warranty extension to 3 yrs for $150
• Precision Made in California, USA
Stage 2
• GIAC custom tuned stage 2 software
• Replacement supercharger pulley for boost increase
• Stage 2 high capacity Bosch fuel injectors
• replacement serpentine belt
• VF-Race bypass valve
• Direct replacement high flow Bosch fuel injectors
Det skal levere 280hk på motoren så jeg håper på 230-240 på hjulene
VR6 POWER
  • 1 month later...
