oil service
pettersenroar
There's no great ''trade secret'' as to how to reset the service indicator lamp on most VW's, simply refer to pages in the Owner's Handbook!
For reference of those interested in such matters, but who might not have access to an owner's manual, this is the procedure to follow:
Note: the Service Reminder Indicator displays 3 messages: OEL, IN 01, and IN 02. These display to alert the driver to follow the items listed under the manufacturer's service interval.
To reset the message displays, turn the ignition switch on. Press and hold the odometer reset button "A" located below the speedometer. Turn off the ignition while holding the button. "OEL" will display on the indicator. Press and hold the lower digital clock reset button "B" until five dashes appear in the display. If needed, press the odometer reset button until "IN 01" appears and then press the clock reset button until five dashes appear. If needed, press the odometer reset button until "IN 02" is displayed and then press the clock reset button until five dashes appear.
To exit reset mode, turn the ignition switch on and when "IN 01" appears, turn the ignition switch off.
On sum golfs you have to turn the milage odometer
To the best of my knowledge, the above service light reset procedure applicable to most Volkswagens
HOPE THIS SAVES YOU PAYING FOR INFORMATION!!!!!!!!!!!!!!!!!!!! ;-)
Håper dette hjelper :) (Og om det står OIL eller OEL i displayet ditt så er det akkurat det samme;))
og odometer = kilometerteller
- 2006 mod. Ford S-Max Trend
- 1999 mod. Volkswagen Passat Trendline stv
- 2002 mod. Opel Astra G Sport
