Russebil
pitersn
Støtter cossie i det over hvis dere må kjøpe fra Norge.
hvis dere kan/vil kjøpe fra utlandet, her USA, så anbefaler jeg at dere tar og selger den 4 kanals forsterkeren og kjøper den jeg linket til, hvis dere ikke vil det så er det bare å se bort i fra forsterkeren jeg linket til.
Forsterker høyttalere: MTX Audio TA7804 Thunder 7804 - 4-Channel Super Amplifier • 200W x 4 @ 2 Ohms RMS • MOSFET power supply • A.R.C. • accent lighting effects • overload and thermal protection • CEA-2006 Compliant - , Car Amplifiers, Multi-channel Amps - Sonic Electroni
Frontsett: Alpine SPR-17S - Type-R 6-1/2" 2-way Component System • Peak: 330 watts • RMS: 110 watts • Impedance: 4 ohms • Hybrid layered-pulp woofer with rubber surround • External crossovers — 12 dB/octave (high -pass) and 6 dB/octave (low-pass) crossover poin
6X9: Alpine SPR-69C - Type-R 6" x 9" 2-way Speakers • Power Handling: Peak: 300 watts / RMS: 100 watts • Full low-frequency response with hybrid layered-pulp woofers • 1" swiveling silk ring-dome tweeter • Frequency Response: 60 Hz - 27,000 Hz • Top-mount
Forsterker sub: ** CRAZY DEAL!! ** MTX Audio TA7801 Thunder 7801 - Thunder Super Amplifier • 800W RMS x 1 @ 2 • 1200W RMS x 1 @ 1 • Prizm EFX • Xtant Cooling Technology • Wired Remote • Built-In Capacitor Terminals - , Car Amplifiers, Mono Subwoofer Amps - Sonic Ele
sub: Alpine SWR-1242D (TYPE R) - 12" High Performance Subwoofer • Dual 4 Ohm Voice Coil • 500W RMS • 1500W Max • Multi-Roll Santoprene Surround • Parabolic Kevlar / Pulp Fiber Cone • CRC Motor Structure • Concealed Mount Gasket System • One-Sided Terminal
strøm kabelsett: Kicker PKD1 - 0/1 Gauge Dual Amp Power Kit • 20' 0/1 AWG Power Wire • 3 0/1 AWG Ground Wire • 20' 16 AWG Remote Wire • 300A ANL Fuse and Holder • 2 Distribution Blocks • 5' 4 AWG Power Wire • 5' 4 AWG Ground Wire - , Car Installation & Accessories, A
RCA 4ch: Kicker KI47 - 4-Channel K-Series RCA Cables • Twisted Pair Conductors • Hyper-Flex Technology • Matte Gold-Plated Split Center Pin • Tactile Grip Duo-Molded connectors - , Car Installation & Accessories, Interconnect (RCA) Signal Cables, 19+ Ft. (6 M
RCA 2ch: Kicker KI27 7 Meter (23.1 ft.) 2-Chan. RCA Cable 05KI27 - 2-Channel K-Series RCA Cables • Twisted Pair Conductors • Hyper-Flex Technology • Matte Gold-Plated Split Center Pin • Tactile Grip Duo-Molded connectors - , Car Installation & Accessories, In
høyttalerkabler: Monster Cable MPC S302 2C 15M - 50 ft. of Red Monster 302 XLN® Speaker Cable (2-Conductor) - , Car Installation & Accessories, Speaker Wire, 12 Gauge - Sonic Electronix
Frakta kommer på ca 400$. Og alt sammen inkludert frakt og moms blir: 11500kr
Uten høyttaler forsterkeren: 9860kr
Eier av en svart Toyota Celica T23 2000mod
