bestille deler frå German Autoparts.
smartman
Har tenkt å betille div til corradoen. Alt av motorlager og paknigsett, motorvarmer og litt eletrisk og kjølvannytstyr.
Dette havner på tilsammen 357.76dollar.
Med dagens kurs tilsvarer dette 1924NOK. dette er jo meget billig.
Viss eg har forstått ting rett er det moms at kjøpssum pluss frakt og ingen toll.
Noen som har erfaringer med dette firma?
Your Shopping Cart Quantity
Corrado Thermostat with o-ring, 80 deg Celsius Low temp 9.38
Corrado Coolant temperature sensor, clip-in style, 20mm diameter. Two pin, black plastic connector. For coolant temperature gauge. Original sensor may be either green or black. Located in coolant flange on cylinder head. 6.80
Corrado O-ring Seal for temperature sensors above. 0.97
Corrado Clip, sensor or plug Holds sensors in place. 0.78
Corrado Block heater kit. Replaces 36mm freeze plug in engine block. Includes heater element and electrical cord. 120V AC. Cord unplugs from heater element so you do not need to have cord attached during summer months when heater is not required. 24.81
Corrado Valve stem seal. 8mm ID. 1 required per valve (8 per engine) 0.98
Corrado Piston ring set, 81.00mm bore. Standard size. Set of piston rings for all 4 cylinders. Ring thicknesses: 1.5, 1.75, & 3.0mm 65.05
Corrado Gasket set, engine block Includes all gaskets and seals required to rebuild engine block. 51.30
Corrado Head gasket set, 1.8L G60 Includes metal head gasket plus all gaskets required to remove, rebuild and re-install head. 120.17
Corrado Head bolt, 8V. Stretch bolt, cannot be re-used. 12 point triple-square socket head, 11x98mm. Includes washer. 10 required 2.48
Corrado Bearing set, main (crankshaft). Standard size. Set of 12 half-shells. #3 bearing has integrated thrust washers. #4 bearing has a 360 degree oil groove for improved oil supply to connecting rod bearings. 39.51
Corrado Bearing set, connecting rod Standard size, with oil holes for drilled rods. Set of 8 half shells. 28.67
Subtotal: $357.76
