Min Octavia RS...
Mikael1977
  • Svar 313
Og SSQV er?
HKS SSQV er den ventilen som lager plystrelydene mine. Den lyden som holder meg ung. :D
Den som sitter opp-ned foran ved innsuget, rett bak radiatoren, ved aircon slangene. Den med den gule silikonslangen.
Vidar - kverulerende eldre drittunge.
Mikael, husker du den visle lyden jeg nevnte jeg hørte hos deg på tomgang (?), ikke forrige gang, men gangen før der?
Jeg kom over dette og tenkte at det hørtes kjent ut:
The Engine Management light came on on my leon cupra a couple of weeks ago! I ran vag-com and cleared the code which had appeared, and since then it has re-appeared 3 more times, the code reads as follows:
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
It always shows the same code and when cleared down it will re-appear, sometimes in a couple of days and sometimes over a week later!
A common cause of this fault is one of the pipes under the manifold perishes and splits letting air in at idle. and blowing crap out on boost. sometimes you can hear the hissing..
if you start the engine and feel the pipes under the manifold round the dipstick, give them a wiggle and see if the sound of the engine changes.
i had this problem. got the pipe replaced and now all is well
