Store sikringer
karljoh
  • Svar 44
heh, ja skal ha Lanzar OPTI6000D ;)
Sitat fra noen som har testet denne:
After I was thoroughly impressed by the power available during my listening session, I put this behemoth on the bench and got down to gathering some numbers from it. The specs in the manual called for 3kW at 4Ω, 4kW at 2Ω, and an astounding 6kW at 1Ω. It did not, however, state at what distortion level those numbers would be attained at, so the printed spec is a bit meaningless. The mighty Cogent test bench is good for up to 16,000 watts of output, and I use a very high quality low noise power supply that will allow me to supply an amp with up to 700A of current at any voltage between 1V and 16V. I dug out my 1/0 power cables and hooked this baby up for some real-world continuous power testing.
While my power measurements were all a bit shy of the printed specs, (see detailed specs below) I can tell you that this Lanzar is one of the top ten most powerful amplifiers I have tested in over 20 years on a test bench. This thing is very, very powerful. And, if you’re planning on using one of these babies to its maximum potential, I can tell you that at full chat into 1Ω, my supply was delivering just shy of 600 amps of current!
Menneeeeh.... hvis man tar feks 2 sikkringer på 250amp hver seg? og setter ved siden av hverandre (paralellkobler) Vil man da få en økning på samme måte som man lærte om motsander i serie og parralell? Det flotte regnestykke med (ampereverdi)\2+(amperevedri)\2=(det du ser etter)\2
Hvis noen er med på det regnestykke?
Får man får vel ikke automatisk 500 amp?
eller blir det hele for upresist og kommer til å ryke uansett?
What good is your 400bhps and sportsuspension when the road is gone due to global warming? Gotta have a big car for that...
hehe, "bare"...
Det står at den er godkjent opptil 470A, ikke at den tåler bare det.
Antar han har tenkt og ha batteri ganske nært liggende til forsterkeren, og den kabelen dær tåler nok 600A uten problemmer på 0,5m. frem til motoren holder det iallefall bra, da jeg tviler sterkt på at han har noe dynamo som yter 470A.
Do-It-Yourself - DIYstash
