Mine feilmeldinger i Vag-com
Shyggen
Noen som kan hjelpe meg å tyde disse?
feilmeldinger:
VAG-COM Version: Release 409.1-US
Chassis Type: 4D - Audi A8 D2
Scan: 01,02,03,08,15,16,17,35,36,37,45,55,56,65,76
Address 01: Engine
Controller: 4D0 907 558 F
Component: 4.2L V8/4V MOTR HS D01
Coding: 04213
Shop #: WSC 00000
1 Fault Found:
17691 - Air Control Valve (N212): Electrical Malfunction
P1283 - 35-00 - -
Readiness: N/A
Er dette idle air valve? eller luftmengdemåler?
Address 03: ABS Brakes
Controller: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D11
Coding: 0273004134
Shop #: BB 24302
1 Fault Found:
00285 - ABS Wheel Speed Sensor: Front Right (G45)
30-10 - Open or Short to B+ - Intermittent
Denne har jeg lest om, og er visst vanlig feil på disse..
kortsluttet ledning bak hjulet pga. kontakt med ramma..
Address 08: Auto HVAC
Controller: 4D0 820 043 K
Component: D2-KLIMAVOLLAUTOMAT D05
Coding: 00080
Shop #: WSC 02314
8 Faults Found:
00715 - Rear Footwell Vent Positioning Motor (V112)
41-10 - Blocked or No Voltage - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
00716 - Air recirculation Flap Positioning Motor (V113)
00734 - Potentiometer in Central Vent (G142)
00722 - Left Center Vent Switch (F183)
00723 - Right Center Vent Switch (F184)
01592 - Air Quality Sensor (G238)
57-00 - Electric Circuit Failure
01273 - Fresh Air Blower (V2)
17-00 - Control Difference
Her fikk jeg lyst å legge meg ned å grine... hva faen?
hele luft driten gått i lufta.. :)
Address 35: Centr. Locks
Controller: 8LO 862 257
Component: ZV-Pumpe, DWA, Funk
Coding: 10184
Shop #: WSC 65535
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch: Passenger Side or Rear
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
Tydligvis noen lekasje på låsesystemet, fungerer helt fint og er vell et helvette å finne fram til den lekken.. så den får være som den er...
Alarm trigger greiene, er dette bare at den føler på di sensorene? eller at alarmen går på di? skjønnte ikke..
trur det må være at di er aktive og klar for alarmering?
End --------------------------------------------------------------------------------------------------
meget takknemmelig om noen kan hjelpe med dette :)
Mvh Raymond Romsdal
Shit happens, ALL the time :)
Det første du bør gjør er å renske alle feilmeldinger, for å å sjekke om de dukker opp igjen.
P1283 - 35-00 - -
Readiness: N/A
Luftmassemåler er det hvertfall ikke. Litt usikker på hva det er sånn på stående fot.
Gåen ABS-føler, enkelt og greit.
Kan få litt sånt spesielt hvis du har vært av med batteriet. Anbefaler deg som sagt å tømme minnebanken og sjekke på nytt etter en kjøretur, spesielt når HVAC'en ser ut til å fungere. Hvis du har gammeltypen styringsenhet kan du også lese ut feilkoder direkte fra panelet.
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
Av en eller annen grunn, har sentrallås-pumpa gått på overtid, og bilen antar at det er pga lekkasje. Hvis du ikke opplever noe problemer med dette, er det nok ikek noe å bry seg om. Resten indikerer at alarmen har blitt utløst av panserbryter, dører har blitt åpent, etc.
ABS følern kommer og går, så dær trur jeg det kan stemme med DIY
http://www.audidiy.com/
Har prøvd å slette feilmeldinger.. men, får beskjed at jeg trenger proff kabel da.. :\ pluss at det programmet jeg bruker it er helt på spor :D ;)
Har hatt løst batteriet ja... men, vifta mi går litt sånn fra og til.. så lurer på om viftemotoren er kaputtski..
Takker for tilbakemeldingen :)
Du får svinge innom ett VAG-verksted, tar jo noen sekunder å slette disse.
Og ABS-følerne kommer og går i noen måneder før de drar inn årene for godt.
ok, leste bare på den loggen på audi forumet.. og feilsymtomet stemmer ganske bra med mine.. så skal skru opp å sjekke om di er slitt ok kommet i kontakt med jord.. ABS følere bruker ikke gå i stykker.. er jo bare en magnetisk sensor.. di bruker å bli full av dritt og da missviser...
ABS sensoren bak ga og feilmelding men, denne fikk jeg rengjort å nå er det problemet borte :)
er ikke no uber verkmester kar, men har bare sjekka litt rundt :D
og forestn, audi hælvette møller.. går fort å slette di ja men, de sku fremdeles ha 500kr for det arbeidet...
Har hatt samme feil på mine, og den var bare periodisk helt til den plutselig ble konstant. Ledningene var fine, følerne var døde.
Skal nå litt til for at de følerne skal klare å slite seg noe særlig, den eneste gjennomføringa er det jo en bra gummikant rundt.
Men er jo verdt ett forsøk :)
