climatronic
pettersenroar
* 1 -- Interior temperature (sensor)
* 3 -- Sunlight sensor
* 7 -- Coolant temperature sensor
* 9 -- Blower speed (adjustable)
* 10 - Measured blower speed (sensor)
* 11 - Defog valve (adj. 0-255)
* 12 - Dashboard ventilation valve (adj. 0-255)
* 13 - Recirculation valve (adj. 0-255)
* 14 - Lower ventilation valve (adj. 0-255)
* 16 - Speed (sensor)
Ett kjapt søk på google gav meg dette,
http://www.bilforumet.no/faq.php
Maks 5 linjer i signatur
By holding and press the 3 buttons at the same time:
"fan speed -" + "blue cooler" + "econ" together, then scroll through the following codes by "blue cooler" and "red hotter"
0. program number
1. inside temp. °C
2. sun intensity delayed *10W/m2
3. sun intensity *10W/m2
4. outside temp. delayed °C
5. outside temp. bumper °C
6. outside temp. air intake °C
7. warming temp. feed room °C
8. warming temp. MAS °C
9. target voltage ventilation *0,1V
10. actuall voltage ventilation *0,1V
11. target temp. Folds Dig.
12. target temp. central folds Dig.
13. target temp. circle folds Dig.
14. target feed room folds Dig.
15. motor running time s.
16. actual speed km/h
17. start Ap Dig.
18. inside/outside folds
19. compressor off code
20. PI regulation Dig.
21. INT regulation Dig.
22. Epsilon regulation Dig.
23. actual out blowing temp. °C
24. target out blowing temp. °C
25. –stop temp. folds Dig
26. RMP zentral folds Dig.
27. + stopp temp folds Dig.
28. Stopp zentral folds Dig.
29. RMP circuit folds Dig.
30. + Stopp zentral folds Dig.
31. – Stopp zentral folds Dig.
32. RMP circuit folds Dig.
33. + stop circuit folds Dig.
34. – stop circuit folds Dig.
35. RMP feed room Dig.
36. + stop feed room Dig.
37. out time min.
38. compressor PWM Dig.
39. target evaporator temp.
40. actual evaporator temp.
41. I-Stell evaporator Dig.
42. epsilon evaporator Dig.
43. refrigerant pressure bar
44. BI level/MAS Dig.
45. engine temp. °C
46. actual evaporator electricity mA
47. target evaporator electricity mA
48. evaporator max.-electricity mA
49. evaporator revolutions 100/min
50. radiator fan heading for signal
51. windshield wiper mode 0=off 1=interval 2=on
52. Fdk-correction windshield wiper Dig.
53. radiator V correction *0,1V
54. reason-number
55. VW-number
56. Hella-number
57. test 1
58. test 2
59. test 3
60. test 4
dette fanj jeg da med litt leting
Måtte ut å sjekke eg, men fikk bare frem 45 program, litt artigt da, men speedoen viser 3km feil i 50km, mot speedo i dash og gps, gps stemmer meget bra med speedo i dash, sikkert pga store hjul,,
eneste eg føler som mangler er boost, hadde vert greit å hatt for å sjekke at turboen funker som den skal,
