Vag com ! trenger litt hjelp med feilene !
Chriis
Nå har jeg kjørt en test med vagcom, fikk disse mld !
Address 01: Engine
Controller: 4B0 906 018 AC
Component: 1.8L R4/5VT 01 0004
Coding: 04001
Shop #: WSC 00028
7 Faults Found:
17746 - Camshaft Position Sensor (G40) Open or Short to Plus
P1338 - 35-00 - -
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28): Incor. Correlation
P1340 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-00 - -
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal
P1639 - 35-10 - - - Intermittent
17521 - Oxygen (Lambda) Sensor: B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
Readiness: 0000 0000
Noen som kan hjelpe meg tyde disse ? :P
Vw Passat sedan 1.8T 99 modell
