Årets julegave tips?
rs_cr
Dette ønsker jeg meg ihvertfall!!!!!!
Med en dollarkurs på 6,9 er prisen ca 10 000.- blank!
Brembo's latest big brake kit with 1-piece rotor comes with powerful 4 piston calipers, carriers, stainless braided brake lines, option of race or street pads, and 13" Brembo race rotors!
Calipers colors are available in black, red or silver. Custom color options are available at an additional cost, contact us for further info.
These rotors have directional veins and are either available in cross-drilled or slotted options. Brake rotors are made from cast iron, these rotors have very similar properties to steel rather that iron. The 13" 1-piece rotor can absorb and dissipate much more heat without warping than most 2-piece rotors.
Brembo’s rotor application uses a 28mm thickness and a Lotus caliper because of its floating pad technology. The floating pad design responds much faster and has no off brake drag such as the Boxster Caliper. Using Goodridge DOT approved brake lines for solid pedal feel you have your choice of pads for street, autocross, or race at no extra charge. Believe it or not the Brembo 1-piece kit is still lighter than the factory brakes!
Available for Audi TT and VW New Beetle, Golf/Jetta 4: 2.0, 1.8T & VR6 engine models.
Price is: $1495 w/ free shipping!
Please contact us for further information.
Autobahn Xclusive - "European Automotive Enhancements"
Web: http://www.AutobahnX.com
Email: Info@AutobahnX.com
Order Toll Free: 1.866.480.2444
Local: 305.341.0627
Fax: 305.341.0628
19"
Fits 1995-2003 Audi A4,A6,A8,S4, or S8
Fits 1999-2003 5-lug VW Passat
Fits 2000-2003 Audi TT and 1999-2003 5-lug VW Golf and Jetta
$1050/set, A+
19x8 in. 5x112mm/5x100mm Lug Pattern
Wheels drilled to fit 5x112mm or 5x100mm
35mm offset
New O.E.R. Wheels made in Italy
Center caps and lugs included
VW Caps available
De finnes til Golf, og Bora og Golf er jo så og si like.
Men noe jeg stussa på var "Wheels drilled to fit 5x112mm or 5x100mm"
Originally posted by PetterJacobsen
19"
$1050/set, A+
35mm offset
VW Caps available
Golf og Bora er helt like. Men Bora heter Jetta i Usa fordi der selger den bra... ;)
Og S3 og A3 har samme boltsirkel.
(S3 finnes ikke i Usa da, derfor de ikke er nevnt med bremsene der tenkre jeg.. )
Vet at de er like, men det som gjorde meg confused var akkurat det du nevnte med "driiled to fit....."
Hvem er det som lager de? er det ikke Toora eller noe som lager RS4 og RS6 replicaene.
Leser til eksamen i markedsøkonomiens utvikling til i morgen... Har "bare" sånn ca 300 sider TUNGT stoff igjen...:(
Huff og huff... :( du får komme deg vekk fra forumet og begynne å lese. Lykke til på eksamen!!!;)
Post her når du får noe mer info om felgene!!
