Sandmos 98 A4 1.6 [TIL SALGS]
Sandmo
  • Svar 1.3k
Da har jeg fått svar fra begge selgerne;
Dear Sir,
pls first exchange ballast between different bulbs to confirm if ballast problem or connector, because our ballast failure rate is very low (less than 1%) ,fathure we tested it and work well before sent out. and we really want to do business with you again for long-term.
Anyway, We will fix it well if really has some problem.
Thanks in advance
Powerlightings
Dear mariussandmo,
Pls send back the defective item to me. I will then send you the replacement once I have received your returned item. The easiest way is to use the original mailing envelope -- just mark it "RETURN TO SENDER", and drop it off at your local Post Office.
Please fill in the Return Item Form by Clicking http://pc-link.biz/return.html
This would help me a lot and speed up the return processing greatly.
My address is :
Ricky Lam
Flat L2, 6/F, Summit Building,
30 Man Yue Street,
Hung Hom, Kowloon,
HONG KONG
Please be sure to include your item no. and email address with the returned item so that I can trace our communications. Thanks !
Sorry for any inconvenience caused.
Winnie-biz
Så da blir det ballaster i retur da!!
Moderator: Bilpleie
