Gløding i vag-com
*euroboy*
Jeg fant jeg fant :)
1) Turn on ignition
2) Go to engine controler
3) Log in using 12233 as the code
4) Click on Adaptation and go to group 12.
5) Change adaptation number from 32768 (default) to somewhere around 32700
6) Click test, then save the new value.
7) Close controler
8) Turn off ignition and turn back on again.
9) Go to the engine controler & log in again.
10) Go to adaptation block 12 and you should see a change in the second window. This value is the amount of time in seconds that the glow plugs will be active.
Note, you must do this with a cold engine to be able to see the results of your adaptation. You can do the adaptation at any time, but won't notice anything till the engine temp is cold. Also, the new glow time will not appear in the second window (no units) after you do the adaptaion. You must turn the ignition off & on and re-log in to the engine controler to see the results of the adaptation.
Link til guide:
Her
