Rockford Fosgate 12" HX2
jorntoffe
husker ikke om det var 2x2 ohm, eller 2x4 ohm spoler på den.
Sakset fra en annonse på 10"
Peak Power Handling: 1000 watts
RMS Power Range: 500 watts
Impedance: Dual 4 ohms
Two 3" 4 Layer LXtended Voice Coils
Coil on Aluminum Former
FIBERLock Cone
Hyper XTended Pole Piece
LXcursion Cast Frame
Dual Laminated Progressive Flat Spider
BART Rubber Surround
CONsealer gasket hides mounting screws and provides an airtight seal
Aeroport Exhaust
Rubber Magnet Boot
Dual voice coil design
LXcursion basket features a deep step that keeps the spider from "bottoming out" and distorting your sound.
