Hello from USA
yeayeayea
Hello, names wes. Sorry, I know zero Norwegian. Anywho, I know Dado on here, and He is a great dude. I shipped him a US spec front bumper (my personal stock bumper) at cost for shipping, and figured I could do the same for smaller parts for others. So is there anything you guys in Norway need from the US for cheap? If I dont have it, I can normally find it with relative ease. for example, I have 2 US spec gauge clusters if anybody cares for that sort of thing, both 8k, 140mph clusters, one just needs the lcd screen replaced.
Feel free to contact me on MSN, my addy is w_e_s_m@hotmail.com, or you can contact me on AIM, my screen name is ghettajetta
Anywho, heres the junker that I drive that is getting switched to carbs this spring
Endret av yeayeayea
VW US SPEC Gauge Clusters for sale, 8K, 140mph, MFA, as is for parts or repair
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=110361990429&sspagename=STRK%3AMESELX%3AIT&viewitem=
The headlights started their life as a cheap set of crystal x-hair headlights
I started with a set of lexus projectors, but later switched to a set of projectors out of some aftermarket mk4 jetta lights, so thats why the two are cut different. I had only retrofitted one lexus projector when i switched
then i removed the lens, and drilled 3 holes to run small bolts from the reflector side of the headlight to the backside of the projector, where i put nuts to fasten the projector to the housing.
then when i swapped out the old rad support for the correct one for round headlights, i removed the lenses, removed the projector shrouds, and painted the housings black so the mounting hardware would be alot less obvious.
I also added a small plate to the projectors cutoff so instead of having a cutoff shaped like the traditional e-code pattern _/ _/ , it is now the standard z pattern _,- _,- to benefit oncoming traffic
Im in the process of securing some more projectors so i can make a couple sets, somebody on here already contacted me about making a set.
I could probably make a set for a mk1 cabby. contact me on MSN w_e_s_m@hotmail.com
or email me at wmurphy1@umd.edu
Endret av yeayeayea
i hope to win the auction for the projectors. so nobody else bid on this :)
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=250374711240&sspagename=STRK%3AMEWAX%3AIT&viewitem=
