Sikkringer Audi 80 2.016vt quatttro.sikkringer
csteinsv
Kan dette hjelpe deg?
1 - 15 Amp Foglights (Front & Rear)
2 - 15 Amp Emergency Flasher
3 - 25 Amp (1990-93)
3 - 30 Amp (1994-95) Horn, Stoplights, Seat Heating
4 - 15 Amp Luggage Compartment, Interior & Vanity Mirror Lights, Clock, Socket, Cigarette Lighter, Radio, Climate Control System, Trip Computer 
5 - 30 Amp Radiator Fan (High Speed)
6 - 5 Amp Right Side Marker Lights
7 - 5 Amp Left Side Marker Lights
8 - 10 Amp Right High Beam Headlight, High Beam Indicator
9 - 10 Amp Left High Beam Headlight
10 - 10 Amp Right Low Beam Headlight
11 - 10 Amp Left Low Beam Headlight
12 - 15 Amp Combination Instrument, Back-Up Lights, Cruise Control, Anti -Lock Brake System (ABS), Cooling Fan Control Unit, Differential Lock (Quattro models), Auto-Check System, Airbag Warning Light
13 - 15 Amp Fuel Pump
14 - 5 Amp License Plate Light, Engine & Glove Compartments Lights
15 - 25 Amp Windshield Wipers, Turn Signals, A/C, Heated Washer Jets, Radiator Fan Switch
16 - 30 Amp Rear Window Defogger, Heating Mirror
17 - 30 Amp Climate Control System (Blower)
18 - 5 Amp Electric Mirrors
19 - 10 Amp Central Locking System, Heated Door Locks, Anti-Theft Alarm System
20 - 30 Amp Radiator Fan (Low Speed), Radiator Fan Relay
21 - 10 Amp Run-On Pump
22 - Blank
23 - 30 Amp Passenger Seat Adjuster, License Plate Light, Driver's Seat Memory Switch Controls, DRL  24 - Blank (1990-93)
24 - 10 Amp (1994-95) Water Pump
25 - 30 Amp (1990-93) Seat Heating
25 - 5/10 Amp (1994-95) Heated Oxygen Sensor
26 - 5 Amp (1990-93) License Plate Light
26 - 30 Amp (1994-95) Trailer Receptacle
27 - 10 Amp Engine Timing I
28 - 15 Amp Engine Timing II
29 - Spare Fuses Not Used
30 - 5 Amp (1991-95) (Not Shown) Cruise Control (4-Speed Automatic Transmission)
31 - 15 Amp (Not Shown) ABS Cruise Control, Differential Lock
32 - 15/20 Amp (Not Shown) Engine Timing III
Administrator
