RE XXX12D2 , sykt bass element! Selges!
Peecc
Har en XXX 12" som jeg ønsker å bli kvitt.
2X2Ω Spoler, 2000w rms, 83.6 dB følsomhet, vekt 32.4 kg (!), lukket + portet
Kjøpte den i desember 2008.
Brukt veldig lite.
Grunnen til salg:
- Penger og mer kraft enn det jeg har behov for.
Ønsker seriøse bud.
Annmeldelse av XXX12!
  Sitat
* 2,000 watt RMS Rated 12" competition XXX series sub
* 72 pound beast!
* This is the best sub in our entire store!!! (We have a lot of powerful subs, this is the best one though)
* 4000w peak output
* Dual Composite 2-piece Cone
* Rubber Surround
* Integrated Gasket
* Cast Aluminum Basket
* Tork-Tite Terminal
* 3” 4-layer Aluminum Voice Coil
* FEA Optimized Motor Structure
* Split Coil Design
* VMS Vented Magnet System
* Dual Progressive Spiders
* Integrated Tinsel Lead
* Mounting Depth - 12.75"
* Mounting Hole Diameter - 11.5"
* Overall Diameter - 13"
* Bolt Hole Circle - 12.25"
* Motor Width - 10.5"
* Motor Depth - 5"
* Basket Depth - 7.75"
* Displacement - 0.24 cu. ft.
* Weight - 72 lbs
* Sealed Enclosure: .85- 2.1 (2.1 is recommended)
* Ported Enclosure: 1.7- 2.2 (2.2 is recommended)
* Electrical Q Value -Qes: 0.46
* Mechanical Q Value -Qms: 3.29
* Total Speaker Q Value -Qts: 0.404
* Free Air Resonance -Fs: 21.00 Hz
* Equivalent Compliance -Vas: 74.0 liters
* One-Way, Linear Excursion -Xmax: 54 mm
* Efficiency -SPL 1W/1m: 83.76 dB SPL
* Effective Piston Area -Sd: 480 cm^2
* DC Resistance -Re: 4.2 ohm
* Nominal Impedance: Dual 2 ohm
* Force Factor -Bl: 18.16
