monoblokk
dunder2k
hei jeg snublet over en forsterker å lurte på om det var noen som har erfaring med de denne?
TL-1021 Class D
Specifications: Output Power (14.4v)
(When bridging the channels)
1 x 8,000 watts Max (@ 2 ohm)
1 x 3,000 watts RMS (@ 2 ohm THD+N < 3.5%)
1 x 2,000 watts RMS (@ 4 ohm THD+N < 2%)
Up to 1 x 3,400 watts RMS (@ 2 ohm)
Up to 1 x 2,500w watts RMS (@ 4 ohm)
(When using both channels individually)
2 x 4,000 watts Max (@ 1 ohm per channel)
2 x 1,500 watts RMS (@ 1 ohm per channel THD+N < 3%)
2 x 950 watts RMS (@ 2 ohm per channel THD+N < 2%)
2 x 600 watts RMS (@ 4 ohm per channel THD+N < 3%)
2 x 560 watts RMS (@ 4 ohm per channel THD+N < 1%)
Frequency response 10 Hz ~ 200 Hz
Subsonic Filter Frequency Range 20 ~ 50 Hz (Adjustable)
Low Pass Filter Frequency Range 40 ~ 180 Hz (Adjustable)
Bass Boost Frequency Range
45 Hz
Input Impedance
67 Kohm
Input sensitivity
0.2 V ~ 5 V
Signal/Noise Ratio (A. Wtg)
1 Watt Reff.
>100 dB
Damping Factor
(100 Hz @ 4 ohm)
>120
Efficiency
82%
Total Harmonic Distortion (THD)
4 ohm loaded 1 Watt 0.20%
800w RMS 0.50%
80% of total 0.70%
Idle Current 2.4 A
Max Peak Current
240 A
Minimum Subwoofer impedance Each channel individually
1 ohm
Minimum Subwoofer impedance when in bridge mode
2 ohm
Power supply
DC 12V
Dimensions
(length x width x height)
dette sier ikke meg så veldig mye så jeg lurte på om dette er bra greier eller bare boss..
i tilleg så jeg denne subben
TL-1121
Specifications:
Parameter
Data Unit Info
Nom. diameter
12 [inch] Nominal diameter (30 cm)
Vas
54.957 [Litres] Equivalent volume
Qts
0.807 Total Speaker Q-factor
Qes
0.905 Electrical Q-factor
Qms
7.339 Mechanical Q-factor
Fs
21.935 [Hz] Resonance Frequency (Free Air)
Sensitivity
90.659 [dB] SPL dB at 1W, 1m
Max Power
3000 [W] Maximum input power
RMS Power
1000 [W] RMS input power
xmax
20.32 [mm] Max excursion from centre at normal operation (one way)
Moving mass
278.9 [g] (Mms) Weight of moving parts
Disp area
0.0434 [m2] (SD), Effective piston area of cone
Disp Vol
1763.8 [cm3] Displaced volume = xmax x 2 x SD
Coil diameter
76.4 [mm] Diameter of the voice coil (Kapton 4-layer - 3")
Cms
0.1888 [mm/N] The stiffness of the driver’s suspension
Magnet weight
5102.9 [gr] Weight of the magnet (180 oz)
Re
1.785 [ohm] DC resistance (per voice coil)
Z
2 [ohm] Impedance of coil (per voice coil)
L
2.23 [mH] Inductance of coil (per coil @ 1 kHz)
Bl
27.529 [Tm] Magnetic strength (Motor force factor)
Recommended sealed enclosure
0.0623 [m3] (2.2 cubic feet)
Minimum sealed enclosure
0.034 [m3] (1.2 cubic feet)
Recommended ported enclosure
Minimum ported enclosure
0.0425 [m3] (1.5 cubic feet)
Krm
2 [m]
Kxm
2.58 [mH]
Rem
5.31
Erm
0.984
Exm
0.656
P max
3,000 Watts Maximum peak input power
P rms
1,000 Watts Maximum RMS input power
Magnet material
High density strontium-ferrite
takker for alle svar..
Forsterkeren er grei den, men det er den samme forsterkeren som SoundMagus X-3200 som ble solgt for 3000,- i Norge, så om du vil betale £1495 for TheLoudest-varianten så er det jo bare å kjøpe! ;)
Regner vel med du får den til "halv pris" et eller annet sted, så for NOK 7000,- eller hva det nå blir, er det jo et røverkjøp i ordets bokstavelige forstand.
