Apexi turteller (Tachometersystem) DECS EL - S ,Apexi Shiftlight Gizzmo Tach Recall
Produktene er helt nye. Gi bud
The new A'PEXi DECS Tachometer combines the classic RPM, warning, and memory playback functions of the previous EL Tachometer with the real time temperature and pressure display of an EL II Meter. This completely redesigned unit uses the same EL (Electro-Luminescence) technology as the original EL Tachometer. Looking to combine as many aspects of engine monitoring into one unit as possible, A'PEXi designed this new tach to employ the new DECS (Dynamic Electronic Control System) technology. The DECS system integrates an optional pressure or temperature sensor to display real time values in a digital readout. Optional sensors that can be used in conjunction with the DECS Tach include: Water Temp, Oil Temp, Oil Pressure, and Fuel Pressure. Temperature values can be displayed in Fahrenheit or Centigrade. The DECS Tach also comes standard with a high intensity, dual stage shift light for accurate gear shifts.
Main Features Include:
- Large, 120mm analog display for easy to read shifting points.
- Digital display built into the gauge face
- Classic EL (Electro-Luminescence) lighting
- Accurate RPM reading all the way to 11,000 RPM
- Progressive number design for better high RPM viewing
- Integrated TEMP, and Pressure reading*
- High intensity shift light included
- Versatile mounting bracket
- Available in white and black face
* Temp, and Pressure reading available only with the use of an optional Temp or Pressure sensor. Sensors sold separately.
Ny pris 4290,-
APEXI
Gizzmo's Tach Recall Shiftlight is a unique dual stage shiftlight which adds additional high spec features into any tacho. The Gizzmo Tach Recall Shiftlight allows any tacho to have a peak RPM saved to memory which can be recalled and displayed at any time. The peak RPM reached during the current trip is available for immediate recall and can be saved to a permanent memory. Shift and launch* RPM is also set and displayed via the factory or an aftermarket tachometer.
* With optional Launch Interface
CONCEPT:
Dual stage shiftlight with integrated memory playback and peak hold capabilities.
CHARACTERISTICS:
- Simple two button operation - Three wire operation - Ultra compact design Specifications Diameter: 22mm Rev Range: 500rpm-16,000rpm Processor: 20mhz RISC with 16 bit timing
Nu pris. 1900,-
Toyota Arctic Truck "35 00(Vinter)(Til Salgs)
Audi S3 03 (Bruksbil)
Honda Civic Turbo 97 (Extrem)
Sponsor: http://WWW.MCARDESIGN.NO
http://WWW.AT-PERFORMANCE.NO
