JChE Skrevet Juni 6, 2009 Rapporter Share Skrevet Juni 6, 2009 Har en slik forsterker som jeg ikke bruker lenger. Ifølge det jeg har klart å google frem, er den fra 2007. Er det i det hele tatt noe verdi i slikt? Ikke mange hundrelappene tenker jeg, men greit å sjekke. Det er 4 kanaler og sikringen er på 40A. Skal prøve å finne noe mer info og poste det her. Siter Bilforumet.noSuper ModeratorNYE FIRMABILREGLER NÅ! www.facebook.com/firmabil 2017 Opel Ampera-E og 2012 Toyota Auris Hybrid Lenke til kommentar Del på andre sider More sharing options...
JChE Skrevet Juni 6, 2009 Forfatter Rapporter Share Skrevet Juni 6, 2009 Fra Zack audio Price: RM 470 BMBOSCHMANN PCH-4882EX (Chromium EX) 4/3/2 Channel 900W MOSFET PWM AmplifierSpecifications :- Chromium combination metal surface,polished BM Logos emblem on top.- Clean,accurate signal amplification.- Higher efficiency than other common designs in the same class.- Uncompromising performance without deterioration of quality through time.- Tri-Boost MOSFET technology with 30% large field effect magnitude.- Active Linkwitz-Riley Design,18dB/oct,24dB/oct cont.variable crossovers.- Discretely Engineered advanced class amplifier topology with low loss rated & improved transient response.- Self-activating on-board Schmidt-Trigger design protection system for total amplifier.- Extrnally variable amplified level controls to enhance musical equalisation & effect.- Low Noise Distortion amplification via BOSCHMANN High Accuracy Common Mode Rejection (HACMR) technology.- Fully automated insertion process on high-value components that ensures the highest grade of amplified sound quality.- Stereo/Mono connection with stabilized minimum load operation while producing a true bridged field effect.Feature :- 900watt 4 Channel, 2 channels for bridged(Subwoofer) and 2 channels in stereo mode(Speaker component)- Class "AB" technology MOSFET PWM power supply- Four Class "AB" high-current dual discrete drive stages- Bridgeable & Tri-mode operation- Soft Start & Muting- Overload,Thermal and Short Circuit Protection- Power and Protection LED indicator- On board HP,LP and Bandpass X-over with frequencies variable- Super Bass,and Treble Boost Level selectable- Thru RCA output,RCA plated Out put to another devices such as Monoblock Amplifier- Chrome Plated RCA Input/Output, Power, and Speaker Terminals- Fuse Rating : 40A- Dimension(mm): W270xH53xD280 Siter Bilforumet.noSuper ModeratorNYE FIRMABILREGLER NÅ! www.facebook.com/firmabil 2017 Opel Ampera-E og 2012 Toyota Auris Hybrid Lenke til kommentar Del på andre sider More sharing options...
cossiemk1 Skrevet Juni 6, 2009 Rapporter Share Skrevet Juni 6, 2009 40amp sikring vil si ca 280watt rms, så da skulle det bli ca 4x70 watt rms på den forsterkeren ;) Siter Lenke til kommentar Del på andre sider More sharing options...
JChE Skrevet Juni 7, 2009 Forfatter Rapporter Share Skrevet Juni 7, 2009 Jeps, ikke rare greiene altså... noen ide om hva jeg kan ta for slikt? 4-500? (trenger pengene mer enn forsterkeren) Siter Bilforumet.noSuper ModeratorNYE FIRMABILREGLER NÅ! www.facebook.com/firmabil 2017 Opel Ampera-E og 2012 Toyota Auris Hybrid Lenke til kommentar Del på andre sider More sharing options...
