Kicker/Sony/MDS
Sebring98
Hei, har litt diverse liggende, alt er nytt,
Kicker KX550.3 forsterker: kr 4000
Kjører 40w RMS x 2 + 200W x 1 i 4 ohm, 75w x 2 + 400w x 1 i 2 Ohm, for de som kjenner til dette/denne vil det si at på denne kan du kjøre frontsett og/eller bakhøytalere + at du har en innebygget monoblokk som drar bra bass.
Alt du trenger i en og samme forsterker
Fant produkt info, se under:
Description: Want a powerful system, but need to save space? Well, that's why Kicker built the KX550.3! Its front, two-channel section really gets your front or rear-deck speakers hopping, while the efficient Class D sub section produces a whopping 200 watts RMS (400 watts RMS at 2 ohms) for some incredible bass.
•40 watts RMS x 2 + 200 watts x 1 at 4 ohms
•75 watts x 2 + 400 watts x 1 at 2 ohms
•3-channel output
•speaker- and preamp-level inputs
•front channels: variable 50-200 Hz high-pass crossover, 12 dB per octave (defeatable)
•subwoofer channel: variable 50-200 Hz low-pass crossover, 12 dB per octave (non-defeatable)
•efficient Class D subwoofer section
•KickBass bass boost (0-18 dB at 40 Hz)
•dash-mountable remote bass level control
•frequency response 20-20,000 Hz (front channels); 20-200 Hz (sub channel)
•4-way protection circuits
•requires 4-gauge power and ground leads wiring and hardware not included with amplifier
•cooling fan
•19-1/4"W x 2-5/8"H x 10-1/4"D (with shroud); 16-5/8"W x 2-3/8"H x 9-9/16"D (without shroud)
Sony XM-XD12X, kr 1000
Forsterkertype: Effektforsterker
Klasse: AB
Frekvensrespons: 5-50000 Hz
Avvik på f.respons: +0/-3 dB
Kontinuerlig effekt RMS v/4 Ohm: 100 Watt
Maks. effekt v/4 Ohm: 200 Watt
Minimum stabil last: 2 Ohm
Kanaler: 2 Kanaler
Sikringer: 1x15
MDS X-MAX12, 12" bass element kr, 1000
12" Power woofer
800W Max. 400W RMS
Pris kan sikkert diskuteres noe, dette skal bort siden det bare ligger å tar opp plass.
Jeg kan nåes på tlf/sms 41327378 eller havard.andreassen@hybeko.no
Endret av Sebring98
